Can I mix it with water?
   / Can I mix it with water? #1
rooster628
South Texas
Fighting s. TX brush (mainly mesquite) and want to know if I can mix the Remedy with water instead of diesel like dad always did? With Remedy at $100/jug, what is the preferred amount of Remedy to use when mixing up a batch?
   / Can I mix it with water? #3
Rooster i use remedy 2 oz per gallon of water, more than normal for spraying soda apples in pastures. Check with your neighbors, i am sure the mixture would be heavier for your application. It may be that some deisel mixed in would have it stick to the plants better.
   / Can I mix it with water? #5
I never used Remedy on my Mesquite but my neighbor does and it's diesel, the diesel sticks to the tree better.
The best method is a bulldozer from what i've seen;)
HAMM HD+ 120i SMOOTH DOUBLE DRUM ROLLER (A52705)
HAMM HD+ 120i...
2004 Workhorse W22 Motorhome (A55758)
2004 Workhorse W22...
2017 Ford F-650 Stakebody Flatbed Truck (A53422)
2017 Ford F-650...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A55788)
2004 Sterling...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
UNUSED IRANCH 16" EXCAVATOR RAKE (A54757)
UNUSED IRANCH 16"...
