Can I jump my DK40SEHST?
   / Can I jump my DK40SEHST? #1
Jmsmithy
Russia, NY & Socialist Republic of NJ
2013 Kioti DK40SE HST
Hello All!
My tractor been sitting for few months. I'm at my camp now and went to start it and got a rapid fire click click (like a machine gun firing, but not quite!). Put it on trickle charger and it's getting 1/2 crank but that's it...not been on too long (couple hours). My question is can I just jump it from my Silverado? It is a small area to make the connections with the jumper cables but I think it's doable.
Figured I'd ask before I possibly fry something....of course no one around at almost 3pm Saturday of a holiday weekend!
Happy 4th of July everyone!!
   / Can I jump my DK40SEHST? #2
You sure can, however I would recommend an F150 for this task instead of your Chevy. . But perhaps that's a different forum. ;)
Hope you have a wonderful and reflective Independence Day!
Also, I bought it new in 2013 and have never had it on trickle charger etc. This is first time ever having battery with low voltage. Do you guys keep your tractors on trickle chargers? I do use mine throughout the year so no "storage season".
   / Can I jump my DK40SEHST? #5
My 2007 DK40se has never failed to start even though it sits unstarted from December to April. Still using original battery. About five years ago I decided it would be wise to leave it on a trickle charger over the winter but even before that it did fine. First start in the spring was always in 30-40 degree F weather.
I'd suggest a trickle charger if not using it for more than a month. Solar powered would be fine if the camp doesn't have mains electric service.
   / Can I jump my DK40SEHST? #6
A regular jump from your truck should start it right up.
I have had my NX sit for several months without running and always starts right up (even in winter) but I keep it inside my workshop. Once, I left the key in the accessory position with the radio on and fully depleted the battery. I tried to trickle charge it with a battery tender, but it didn't work. Had to jump it, which worked great. May have been partially because the charger was poor quality (HF). Enjoy!
   / Can I jump my DK40SEHST? #7
As others said, jump start from your truck should start it right up. Using a trickle charger you'd have to wait over night before the battery had enough juice to start it. Jumping from the truck will get it going then the charging system will top it off.
   / Can I jump my DK40SEHST? #8
I use a a desulfating charger .. batterymider. Amazon.com: BatteryMINDer Model 151: 12Volt 1.5 Amp Maintenance Charger/Desulfator: Automotive
My tractor use to site for months at a time and never had a problem starting it until 2 years ago.... and that battery was old, as in over 5 years old. I needed to get my tractor moved and since I couldn't start it with a portable jump starter, I picked up a new battery and the batteryminder. It's suppose to keep the battery desulfated, so I'm hoping I won't need to replace the battery again for a decade.
   / Can I jump my DK40SEHST? #9
Red from the truck to red on the battery.
Black on the truck to a good ground on the tractor frame, NOT TO BLACK ON THE BATTERY.
   / Can I jump my DK40SEHST? #10
Probably safer to say to match +/- polarities.. With last connection to chassis.
Kubota ZG327 (A50121)
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
Cat DPL40 Forklift (RUNS) (ENGINE KNOCKS) (A50774)
Cat DPL40 Forklift...
Hester 1206 10' V Disc (A50121)
Hester 1206 10' V...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2015 Kia Cadenza Sedan (A50324)
2015 Kia Cadenza...
