Can I ask for help choosing the best length for a hydraulic top link?
   / Can I ask for help choosing the best length for a hydraulic top link? #11
I believe the lower links (lift arms) he is talking about are the vertical arms that attach the lower lift arms to the upper lift arms. Extending those will allow for the lower arms to move lower but they will not raise as high as before. By keeping the top link constant and allowing the arms to go lower it provides a more aggressive angle of attack for cutting/digging implements - i.e. box blade, subsoiler, plow, etc.
   / Can I ask for help choosing the best length for a hydraulic top link? #12
Here is what I typically have my customers do when there are questions about what working length to get. With that measurement, I try to have the cylinder so that it will retract 1/2"- 1" more than it will extend. Overall this is a pretty good gage as to what you need. Everyone's needs are a bit different, only you can make the decision as to what will work the best for you. Here is a link to a different supplier that has several different working lengths in stock.
   / Can I ask for help choosing the best length for a hydraulic top link? #13
Can't get much better info or service than this.
1049 (A50459)
1049 (A50459)
MUD MIXING UNIT (A50854)
MUD MIXING UNIT...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
