Can hooking up the backhoe be a one person job
   / Can hooking up the backhoe be a one person job #32
I have basically the same tractor (model number changed one month later). I can take the BH off in under 3 minutes. Piece of cake. Some times it takes 10 minutes to put it back on.... most of the time about 5 minutes.... also by myself. A second person can watch the subframe to make sure it is lined up. That is about all they could do.... having a second person helps so that the operator doesn't have to keep getting on / off the tractor.
There are too many small details to explain posting here... My suggestion is to YouTube "removing LS XJ2025 backhoe" , (the XJ2025 has a similar mounting) there are a few really good ones about it. I think there is only one for the MT225E / XG3025 (Same tractor). Also the Kioti CK2610 has the same identical subframe mount. There are some videos showing that removal.
The key 'take away' is: With practice it will become very easy! The first time will take quite a bit longer.
   / Can hooking up the backhoe be a one person job #33
Reading this makes me feel inadequate. I have a heck of a time switching the finish mower for the bush hog!
And I have pics showing what it’s supposed to look like after hook up.
I hate to admit, but it probably takes me 39 minutes to complete the process. I’ve learned a few new words as well.
MoKelly
Just be thankful it does not take you 40 minutes.:ROFLMAO:
   / Can hooking up the backhoe be a one person job #35
I can take my BH off in 5 minutes, mounting takes 5-10 minutes, just depends. I use a stack of 4 to 5 2x4's to place under the boom pivot to keep it from tipping the front of the subframe up as the hydraulics equalize when it's sitting disconnected.
Removing it is easy, put stabilizers down, uncurl bucket fully and lower boom and adjust dipper so that it is vertical. bucket teeth will sink into the ground some which keeps it in place and allows you to use the hydraulics to position the BH back on later.
I nudge the stabilizers and boom levers to just lift the subframe off the rear mount plate and to basically center the front plate in the 2 cutouts.
Slowly drive the tractor forward to just clear the rear mount plate. I then place a 2x4 under the front and rear most portions of the subframe so it doesn't sit on the ground. Place the stack of 2x4's under the boom just behind the pivot pin. Use the boom and stabilizer levers to lower the BH onto the boards.
My BH connects to the rear hydraulics with detent so I just place the lever in the neutral position.
Now carefully work all the BH hydraulic levers to help remove pressure then disconnect the hoses.
If the BH may be left uncovered a few days, I take a large white trash bag and cover the levers, It will slide right over them all and makes a pretty tight seal around the BH console.
To install, Basically reverse the process. I do use the BH levers for boom and dipper to do the final placement back on the subframe mounts.
Here is the stack of 2x4's I glued and screwed together in use once when I took it off on concrete.
   / Can hooking up the backhoe be a one person job #36
Out of curiosity do you park on a smooth, level concrete slab? If not, try it.
   / Can hooking up the backhoe be a one person job #37
Kioti backhoe attachment is a one man job with typically 15 mins for hookup. But like everything in life, the more experienced you get at it, the faster it goes. Focus on the tractor alignment for best results. And always remember to remove pressure on your hydraulic lines before disconnect, or you will have trapped pressure in your backhoe next time you hookup. Always park on as level ground as possible.
   / Can hooking up the backhoe be a one person job #38
MoKelly
In any installation there will be a situation unique to your own setup. Both the implements and tractors are variable. Small position adjustments are necessary and you dont want to be stuck doing them with a crowbar. An HST tractor gives most control, but I think any tractor with a loader can do almost as well in fine adjustment using the bucket - edge down. Lift the tractor front slightly and then use curl and dump (carefully) to make small back and forth movements of the tractor as needed. You can even vary the amount the tractor front is lifted if you need small changes in height or rotation of rear attachment points. Once you get the process down it isnt a struggle any more.
   / Can hooking up the backhoe be a one person job #39
MoKelly
When I got my first real CAT II implement...yeah, there were some words that peeled some paint.
   / Can hooking up the backhoe be a one person job #40
When you remove the hoses hook them
together
Chect these videos out should help!
willy
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
UNUSED RAYTREE REDM32 HYD EXCAVATOR MULCHER (A57193)
UNUSED RAYTREE...
(INOP) 2007 HONDA 420 ATV (A57192)
(INOP) 2007 HONDA...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
UNUSED INDUSTRIAS AMERICA SK 72" HYD BRUSH CUTTER (A57192)
UNUSED INDUSTRIAS...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
