Can anyone tell me what conversion fitting would fit my current valve from this site
   / Can anyone tell me what conversion fitting would fit my current valve from this site #1
acadian32
Ottawa
Jinma 254
Good evening all, can anyone tell me what conversion fitting I need from this store world wide metric?
I have yet to find specification info for this FEL valve as to thread size and fitting type. thank you all.
   / Can anyone tell me what conversion fitting would fit my current valve from this site #2
That appears to be a 14mm ORFS on the power beyond port. What are you trying to do?
Good day Bob, I have a leak at the elbow joint well a drip so because those are odd size was thinking of getting conversion fitting from the at store I mentioned above see pictureValve leaking.jpg
and no I not planning on replacing the engine just jocking because as you know parts are not locally available in Canada :) pain in the """
   / Can anyone tell me what conversion fitting would fit my current valve from this site #5
Good day Bob, I have a leak at the elbow joint well a drip so because those are odd size was thinking of getting conversion fitting from the at store I mentioned above see pictureView attachment 425223
Did you put a new O ring on when you put the hose back on?
Hello Xfaxman, the only o-ring that I know of is the one you see on the picture is there another o-ring then the one you see on the picture thank you
   / Can anyone tell me what conversion fitting would fit my current valve from this site #7
No, that is the one, did you replace it?
And you never answered in the other thread, were is it leaking, there are three possibilities.
Tightly wrap a rag around the fitting and see were it gets wet first.
attachment.php
good day I thought it was clear on my picture sorry about that its leaking at number 2
Good day all. just a quick FYI I found the 2 conversion fitting for my spool valve and works great the in put and out put size is 15MDL-8MJ / Metric Conversion Male DIN 24* Cone Light Series to Male JIC 37* Flare Thread {1}: M22 x 1.5 Thread {2}: 3/4"-16 ( $32.00 each )
I ordered the 4 others for future use is I get a leak.
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2012 International 4300 Reefer Truck (A53473)
2012 International...
Ford Super Duty 8ft. Truck Bed (A51692)
Ford Super Duty...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
