Backhoe Can a SubFrame JD4310 attach to a JD4110?
   / Can a SubFrame JD4310 attach to a JD4110? #1
need4info
Waterford, Ontario
John Deere/New Holland
I have a Wallenstein backhoe GX 600 on a John Deere 4310 subframe! Can it be attached to a John Deere 4110? Any helpful advise would be appreciated. Thanks.
   / Can a SubFrame JD4310 attach to a JD4110? #2
:welcome:
Cannot say for sure, but I believe the 4310 is a larger frame than the 4110.
Not exactly sure what you refer to when you say "subframe".
Others may be a lot more help.
Thanks. This is new territory for me (Forums & tractor attachments). Sub-frames are generally bolted on and can be interchanged to suite the model correct?:confused2:
   / Can a SubFrame JD4310 attach to a JD4110? #4
The picture of the frame that you added does help. ;)
I'd suggest measuring it and see if the frame has a place to bolt it onto the 4110, or if not then how might it be altered to work.
Still would be sure that this backhoe is not too large for the smaller 4110.
That said, a search turned up this thread that just may be very helpful to your decision.
http://www.tractorbynet.com/forums/...29428-picture-wallenstein-backhoe-jd2210.html
Some pics there showing the hoe on a 2210 with some warranty comments.
   / Can a SubFrame JD4310 attach to a JD4110? #6
Did you/are you purchasing or selling that backhoe? That looks like the backhoe listed for sale near Brantford. FYI, you can purchase a brand new Bush Hog 665BH for $3500 CAD w/out subframe or pump.
I have no association with the dealer. I just noticed the ad. If you are shopping compare specs before you purchase.
Brindley Auction Service
Sedan (A59231)
Sedan (A59231)
INOP/NON-RUNNING 2012 Jaguar XJ Passenger Car, VIN # SAJWA2GE5CMV37496 (A57453)
INOP/NON-RUNNING...
1997 DORSEY AIDT-LSCG 53 FT DRY VAN TRAILER (A59575)
1997 DORSEY...
Werner 28ft Fiberglass Extension Ladder (A57454)
Werner 28ft...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
(7) Ten Hole 25 Inch Steel Rims (A57454)
(7) Ten Hole 25...
