Can a Compact Tractor do it?
/ Can a Compact Tractor do it? #11
Check out an American company called Power-Trac at their www.power-trac.com website. They offer 45hp or 65hp (2400 series) machines w/ backhoe that you might find interesting.
Good Luck!
/ Can a Compact Tractor do it? #12
Snave,
Which part of Abaco you in??? My mother-in-law grew up in Cherokee Sound. We go down there a couple times a year.
Based on what I have seen you need more than a compact tractor to do work on the earth there.
The boat trip form the mainland to Marsh Harbour would be pretty expensive to ship the unit in.
Thanks guys. I went with the skid steer and arranged for a machine with some attachments that should make things a little easier. Should get it Wednesday. It won't do everything, but its a start. The backhoe will have to wait. And I still want a tractor.
Wasabi - those machines look awesome. I will definately place one of these on the top of my wish list for the next machine. Nice on terf and can handle slopes. Lots of power. More than lots of attachments. Good prices. Not bad.
Sniezur - I live in Marsh Harbour. Cherokee is at the other end of the earth. Just joking. But the long and winding road to get there makes it feel that way. Its 12 miles in according to the sign, which someone amended to read 112 miles.
The land is pretty rough. And getting things over here is expensive.
Doug Evans
/ Can a Compact Tractor do it? #14
Snave,
Do you know Kevin Sawyer??? He is my wife's cousin and he works at the nursery right by the airport.
I will have to give you a shout when we are down there this fall visiting.
/ Can a Compact Tractor do it? #15
Sorry, I asked this question on another thread -
I've got a dense layer of 3 or 4 inch diameter rocks about 8 inches under the surface. You can dig them by hand with a heavy shovel, steel digging bar, and softening the ground with water. A 2-hp handheld gas auger is stopped cold by this layer.
But, as I've got over 300 post holes to dig, I'm trying to figure if a Kubota BX22 has the power and weight to handle this with a PTO-attached auger, as well as get through this layer with the backhoe for trenching. Otherwise, I'll get a Deere 4210 which weighs 1000 more pounds and has about 50% more PTO horsepower, and which is the same price, although sadly *without* a backhoe.
I'd buy the Kubota if I was reasonably sure it could do it, but the nearest dealer is 67 miles away with totally different soil conditions, so there can't be any kind of trial run before a purchase.
/ Can a Compact Tractor do it? #16
Ive only dug 9 post holes (175 more to go - 9" auger) with my TC25D so I'm no expert but I don't think hp will help you dig post holes better. (Someone correct me if I am wrong /w3tcompact/icons/smile.gif)I run my tractor barely above idle when I am digging. If I increase the rpms I break more shear bolts when I hit rocks. If I'm just above idle, the auger will bounce and, if the rock is small enough, it will work itself loose and come up. When I do hit rocks, it jostles the tractor a bit but nothing major.
Of the nine holes, all of them are 36" deep except 2. Those 2 holes are about 30" deep. In each case I hits rocks I could not get through. My only recourse would have been to use a sledge hammer and something (digging iron?) to break them up. However, I had no idea how thick the rocks were. In one case, it covered the entire bottom of the hole while in the other case it covered half the bottom of the hole. In both cases I would have 'destroyed' the hole to get the rock out. So, I used 2 bags of concrete in these 2 holes instead of 1.
If you know you're going to hit rocks, you might want to seriously consider a digger with a slip clutch. Also with rocks, you will probably have to get off the tractor to clear rocks out of the hole, I know I did. In such situations, resist the urge to try it with the auger running. Stop the auger, clear the rocks/dirt, get back on the tractor and start the auger.
/ Can a Compact Tractor do it? #17
I agree with MikePA, I use my PHD the same way, just above idle. The additional hp and weight would not help with a CUT. You might want to rent a Bobcat with a HD auger that has downforce.
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
2016 KENWORTH T880 TRI-AXLE DUMP TRUCK (A62130)
2016 KENWORTH T880...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
