Can a B7800 Grade a Driveway?
   / Can a B7800 Grade a Driveway? #1
CMRVA
Richmond, VA
Kunota B7800 (2004)
New owner with about 2400 feet of gravel driveway. Is this machine big enough to do a professionally looking job regrading the driveway? Do I use a box blade for that? Thanks
   / Can a B7800 Grade a Driveway? #2
Yes and Yes.
Skill requirements may vary.
   / Can a B7800 Grade a Driveway? #3
If I had that long of a driveway, I'd build a knockoff of one of the graders made for road dragging. You'll be using it every few months or more to keep it in great shape. With those, you drive down the outside and it pulls to the middle. A lot less forgiving than a box blade.
Sure you can do it with a box, but why not make it easier?
ron
   / Can a B7800 Grade a Driveway? #4
Yep for a driveway that size get a rear blade that you can angle and it will do a great job!
   / Can a B7800 Grade a Driveway? #5
Give it a whirl...yes...take your time until you get the nack...even rake will do nice job.
   / Can a B7800 Grade a Driveway? #6
I use a york rake on mine. I think you will find that if you have a crown, you may need to angle the rake accordingly.
Takes maybe an hour to get it right, but I am only about 1700 feet.
-Mike Z.
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2004 Ford F250 (A50515)
2004 Ford F250...
2008 VOLVO VHD64B CRANE TRUCK (A52141)
2008 VOLVO VHD64B...
2012 Ford F-150 (A50120)
2012 Ford F-150...
2013 Ford Transit Connect (A47384)
2013 Ford Transit...
2014 Ford Fusion Sedan (A50324)
2014 Ford Fusion...
