Camp property found, now updates.
/ Camp property found, now updates. #881
A big reason for buying a tractor was so I no longer need to lift stuff.
The tractor would need to be at the propane refill station - good for offload but not loading, We have a 2 wheel dolly with a set of 5" casters on the top/back to lay things horizontal for moving or loading heavy stuff.
/ Camp property found, now updates. #882
Got a 100 gallon propane tank recertified and refilled today. Putting it in the back of my truck nearly killed me. 😣 Might have to sell it.
Should use that single axle trailer to haul that tank, not put it in the truck. I have 2 of those tanks and use a single axle trailer to take them in for fill up. Easy to roll on when empty, leave tank vertical and tie down with 4 ratchet straps. Fill station usually puts it back on the trailer using a 2 wheel dolly, I just have to tie it down. Hardest part is getting the full tank to roll down the back gate without losing it then roll back into place. Trailer is much easier than trying to load into pickup. I lift it off my trailer with my tractor loader and a chain.
/ Camp property found, now updates. #883
I think we might be talking about a 100 lb propane tank, not 100 gal. 100 gal would be over 400 lbs. The tank in the back on the UTV here looks to me like a 100 lb tank, which is around 20 gal. Still heavy, mind you.
I believe I did originally state 60lbs. I put it in the back of my truck when filled. I don't want to do that again.
/ Camp property found, now updates. #885
Did you put a hoist on one of your trailers awhile back?
/ Camp property found, now updates. #886
Can you pull your utility trailer with your 6x6? Id rig something to lift the upright full tank out of trailer if you still have that hoist and that trailer could be pulled with your 6x6. Or as others said get a tractor rig some way to lift that tank with the loader.to load and unload at your place.
NOAA moderated the rain over the weekend so we are heading to camp Saturday am. 👏 I'll get some photos of the 100lb tank and see if I can sell it locally. Need to pack essentials to bring along.
Don't like these propane lights here. They Somke, and don't put out much light. We'll need to look at a larger solar panel instillation.
/ Camp property found, now updates. #891
Replace the cloth mantles? Took me awhile before I figured out how to correctly use my portable propane lantern.
/ Camp property found, now updates. #892
Is it cheaper to run propane lights or the little Honda Generator?
/ Camp property found, now updates. #893
LED lights even run off a 100aH LiFePO4 battery will last a LONG time. Bring it home every 3rd time you're there and charge it up, no need for solar (yet) if you just need lights I am partial to the warmer color LEDs (<4000) but that is a personal preference. LiFePO4 batteries are getting pretty cheap on AMZN lately.
/ Camp property found, now updates. #894
Dust?
Can't write much with just one or two bars at camp. We'll investigate the propane light thing but the original owner did add a small solar panel after year of propane lights use. He talked about how well it worked. So far we'd agree.
/ Camp property found, now updates. #896
Have you looked at solar shed lights with a battery? If there inexpensive enough maybe get them for temporary use til you get a decent solar array set up? Led lights definitely use a lot less battery juice and have come a long way since the older bright white light ones.
/ Camp property found, now updates. #897
I was thinking battery powered led lights also like Hawkinshollow said. The batteries last for ever or rechargeable ones would be good too.
/ Camp property found, now updates. #898
Problaby id make sure the charge controller if solar or battery charger is rated for lifepo batteries.
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 INTERNATIONAL...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A63688)
2022 Schulte...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2006 Kawasaki Bayou 250 (A64127)
2006 Kawasaki...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
New Holland 3930 (A60462)
New Holland 3930...
