Cam replacement on 7822 rake
   / Cam replacement on 7822 rake #1
limey
St Paul Ab. Canada
Kuhn 7822 rake
I'm replacing the cam in the rear rotor on a Kuhn 7822 rake. This is a big job. The shop manual suggests you can just drive the main pin down from the top. We've moved it about an inch now its stopped. does anyone have any experience working on the rear rotor? It's a fair bit different from the front one. We are going to split the top arm casting that bolts to the top of the masterdrive, I think there maybe a keyway on the cross member that carries the frame support for the tarp and lights.If anyone has ANY suggestions I would appreciate it. Thanks
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
TANK MANIFOLD (A58214)
2013 CATERPILLAR 950K WHEEL LOADER (A60429)
2013 CATERPILLAR...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
