Calling the Hay Dr...............
/ Calling the Hay Dr............... #1
CumminsLuke
east central Missouri
Hay Dr, with your vast knowledge of everything hay, I wanted your opinion on whether or not I can pull a Case-IH 8450 4'x6' baler with my Kubota M7040 that is putting out 62pto hp. I would not make a full 6' bale, I'd stop at 5'. My fields are mostly flat except for one, and it is not to bad. This baler is in my price range, and I know it is in good shape as it belongs to a dealer friend of mine and his son in law has been using it on their farm, and he has replaced every bearing in the thing as well as some other stuff. We are just not sure if my 7040 will have the umph to pull it? I'd like to find myself a nice 4'x5' but everything I can find that is decent is priced too high. I don't want to give more than about $5,000 for a baler.
/ Calling the Hay Dr............... #3
I'm not the Hay Dr, but I may be able to help.
The farmer who mows, rakes, and bales my hay has the same baler you are considering. He uses an old JD 3020 to run his baler. The JD works pretty hard when the chamber is full, but it does the job. If I remember correctly, the JD 3020 is about a 60-65 HP tractor when it was new, but I doubt it's producing that kind of power now. He rolls 5' bales instead of 6' bales. Last summer, he rolled 200 round bales in three cuttings on my 30 acre hay meadow.
Bill
/ Calling the Hay Dr............... #4
Not a Dr. either but,
Couldn't find the specs on the baler you are talking about so compared the Vermeers 504M and 604M off the website for reference. They recomment 55hp pto for the 504 and 70 pto hp for the 604. It may not be exactly apples to apples but it sounds like you could get the 5' bale ok. Your post had me curious and I checked tractorhouse for a price comparison. Most were $6500 or so that I saw listed.
Well, like I said, this dealer is a good friend of mine, he is my sons God Father actually, so he is gonna make me a pretty sweet deal. I think I can get it for around $4,500. He also has a nice 2005 NH BR740 4'x5' that calls for 60 hp. I think it would make a good mate to my tractor, but it is around $11,500 to me. I only bale about 300-400 bales a year so I am having a hard time justifying $11,500.
I have a guy who works for me who used to pull a JD 530 with a 3020 diesel to a 5'x5' bale. It'd make it grunt a little but he did that for years. Beings a 3020 diesel was 65 pto hp and I have 62, I'd think I could pull a 4'x6' to 4'x5'?
I am considering these machines, Case-IH 8450/Hesston 550, NH 640 or 650, or a JD 430. But I'd probably stick with the Case-IH/Hesston or the NH as those are the brands my friend sells and services.
/ Calling the Hay Dr............... #8
I'm not sure of the model numbers, but somewhere in the year ranges your looking Case-IH(New Holland??) offered a fixed chamber/soft core baler. The advantage of those is you can bale hay a little wetter if you need to, but the big disadvantage for you would be that it makes a lousy bale if you have to tie if off short of full size. With the regular hard core baler you can have a decent bale even if you end up closer to 4x4 than 6x4 on the bale size.
The one you had in the ad looked clean.
/ Calling the Hay Dr............... #9
The Case-IH 8450 should pull with 55 HP for dry hay and 65 HP for haylage.
You can pull this baler with a M7040 but may have to change some gears when you get to a hill.
The HayDR
/ Calling the Hay Dr............... #10
The 8450 is from when Case-IH still was tied in with Hesston. The NH/Case-IH balers started just a few years ago.
The HayDR
Thanks a lot for the info. I am thinking I am gonna try the 8450.
/ Calling the Hay Dr............... #12
I know it's been quite a few years, but did you buy the 8450? I am looking at one to buy now. Was wanting to get any advice?
2017 JOHN DEERE 317G SKID STEER (A65053)
2017 JOHN DEERE...
2022 EZ-GO ELITE...
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
2023 Mercury Verado 350HP Outboard Boat Motor (A64557)
2023 Mercury...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
Hydraulic Breaker Excavator Attachment (A64553)
Hydraulic Breaker...
