Pat's Easy Change Calling Pat’s Cat 2 owners - Are you happy?
   / Calling Pat’s Cat 2 owners - Are you happy? #1
BellyUpFish
Florence, Al
Massey 4243
Long story short, I’ve got a 85hp MF. I’d love to have a smaller tractor but this one is paid.
I mainly use 3 attachments - bush hog, box blade and a grader blade. I’m also contemplating a land plane.
We typically leave the bush hog on, which is a pain due to how long it is. Makes it hard to work around the house. It’s really too big to be doing that anyway, but it is what it is. Lol
So, I’m looking at Quick Hitches and it seems like the Pats is going to be the best setup for me.
I’m looking at going with their Cat 2 easy change, but I recently read some comments that the Cat 2 guys tend to have issues over the Cat 1 guys.
The MF has adjustable lower lift arms and I’ve also read these combined with the Pat’s is basically a waste of time/money.
I want to be spinning my wheels on a fix that isn’t helpful.
How do you guys using the Cat 2 PEC feel about them? Happy with them?
   / Calling Pat’s Cat 2 owners - Are you happy? #2
Exactly my situation with both my large frame Kubota's and I've always felt they would be a waste of money in as much as the lower lift arms are already adjustable. They ain't cheap either.
   / Calling Pat’s Cat 2 owners - Are you happy? #3
Not exactly apples to apples but have cat2 to cat1 Pat’s quick hitch on the Kubota M59. Most attachments are both cat1&2. With pin adjustable sway bars makes easy to hook up. Tractor is unique as it has hand creeper control accessible from the rear adds to easy hook up control. Just bump and lift. Like the lift added length on the PTO gave room for an overriding clutch.
Have had tractors with adjustable lower arms and agree they help considerably and not as much to gain by adding Pat’s.
Pat’s on the cat1 on the B26 gives easier pto hook up.
Nine years using Pat’s and only complaint is the adjustable jam bolts are a weak point. Some have used higher grade bolts. I think welding shims would work better but haven’t gotten around to it.
   / Calling Pat’s Cat 2 owners - Are you happy? #4
I'm considering either Pat's,Tooltuff, or MotoAlliance brand. Can't make up my mind, even with the considerable price difference.
The MotoAlliance has a wedge that must be removed/installed each time.
edit: The Pat's and Tooltuff has a spring that might be problematic.
   / Calling Pat’s Cat 2 owners - Are you happy? #5
The heavier the implement the more I’ve seen complaints from PEC. That said, your list of implements isn’t that demanding compared to say an offset hay mower or needing to till 40 acres. I suspect they’d hold up fine if you’re more somewhere around a weekend warrior or light duty hobby farmer.
Kind of a hard question on if the PEC is gonna save you that much more time vs the extendable links you already have though. If you really struggle with the extendable links then maybe it might be worth it.
So you know my bias I have three tractors with euro hooks. I even took the extendable links off my 80HP Deere and went with hooks. On my 8ft flail mower I’d fight to get the links to latch back into place after extending them. They run about the same price as a PEC but you need to be able to weld or add that to the price.
   / Calling Pat’s Cat 2 owners - Are you happy? #6
Not too many complaints about the Euro hooks. Nothing like the Pat's anyway.
3 common sizes. cat 1, cat 1-2, cat 2. Even cat 3 & 4 available.
My recommendation is cat 1 for under 3000lb lift capacity. Cat 1-2 for 3000lb-5000lb capacity and cat 2 for over 5000lb 3pt lift capacity.
Do the fabriction yourself and save some money, or ship the draft link pieces and pay to have the fabrication done.
Just an alternative to be considered.
I’ve been considering Euro hooks.
Seems like it’d be the best of both worlds.
I can weld, so that’s an option.
   / Calling Pat’s Cat 2 owners - Are you happy? #8
You won't regret it, that's for sure. Well worth the money and time invested to install those.
   / Calling Pat’s Cat 2 owners - Are you happy? #9
I bought Pats before I learned about Euro hooks. The Euro hooks looks like a better system but I was already using the Pats cat 2. So if they fail I'll go Euro hooks. But 2 yrs in it's so far so good.
I have extending links but honestly when used they often wont slide back in until I push the attachment against the barn pillar...which I don't like doing
   / Calling Pat’s Cat 2 owners - Are you happy? #10
I had Pat’s for years on a smaller cat 1 tractor. Now my cat2 tractor has adjustable lift arms and top/tilt hydraulics. With those features, attaching and detaching implements is pretty easy.
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A53422)
2019 Ford F-150...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2007 INTERNATIONAL 4300 26FT BOX TRUCK (A56138)
2007 INTERNATIONAL...
