Calling all 2520 owners
/ Calling all 2520 owners #21
Yes they have been out for several years. I can't believe it's taken this long for people to notice this. I have two JD implements that barely fit and rub the tires and I need to use one of them with tire chains. Never gonna happen when the arms are that close to the tires. And think about it, if they barely fit once hitched up then that means it's really hard to get the draft arms over the ends of the pins. I basically have to pry the arms out against the tires one at a time to get them over the ends of the pins. This is just not right. I am going to have to fix this one way or the other and I'll be darned if I'm gonna pay $600 to fix a brand new tractor! The biggest problem we're all going to have getting JD to fix this is that the Cat 1 spec. does not say anything about width across pins. So JD can just say that our implements just aren't made right. That's what my dealer first said. I reminded him that they are JD implements that don't fit a JD tractor. Rats, now I'm pissed off again.
/ Calling all 2520 owners #22
My dealer called me yesterday and told me my new arms are in and they will correct the problem free of charge! I'm glad used it most of the day yesterday with rotary cutter and it is a pain in the butt.
/ Calling all 2520 owners #23
do you know if your dealer has a dtech (and what is the number?) authorizing free replacement of the arms? or is this something he is offering to do on his own? thanks
/ Calling all 2520 owners #24
Thanks op
I called and spoke with a friendly gentleman named Isaac.
He documented my problem and said I should contact my dealer.
I will report back with my results.
/ Calling all 2520 owners #25
spc- it was done by dtech- I had to answer a few questions on a form for my dealer and he turned it in and a few days later he called with the good news. my tractor is up at the mntn house, where we are this week and I will trailer it home on Sunday for the repairs.
/ Calling all 2520 owners #26
bz1 - Which JD implements do you have?
/ Calling all 2520 owners #27
I too complained to JD corporate a few days ago. When the supervisor called me back yesterday I gave her a real earful about standing behind their product. Today, the JD Regional District Manager called me to advise that JD will be issuing an update to the DTAC case in July '08 advising the replacement of 3ph arms on the 2520.
This should give the dealers what they need to begin the warranty replacement claim.
In the interim, he suggested that put a claim in with the dealership so it gets dealt with once the DTAC is amended with the new solution.
GN
/ Calling all 2520 owners #28
rssnjr, I have a 7 foot back blade, I think it's called a model 45. I also have the 4 foot rough cut mower (bush hog) which I think is called a model 48. Neither one will fit between my tires and the pins cannot be turned inward on these units. Each unit is about 8 years old. I am so glad some of you have finally gotten news about a free draft arm fix. I'm still have not heard from my dealer but he will hear from me this coming week. I hope this means we all get the fix.
/ Calling all 2520 owners #29
Hi all,
I have been so busy lately that I still haven't stopped by my dealer to do whatever I need to do to get my 3 point arms replaced. And yes, I've also had the problem with the #46 backhoe brackets digging into the front tires. It happens when you turn tight on un-level ground and the front axle needs to pivot to compensate.
As far as anything that has been said about the Cat1 3 point "standard" spacings, all I can say from my experience is the following. I've used the same Woods box blade and landscape rake (that causes rubbing on the 2520) on my old 755, on a 4210 I rented a couple of times (due to 5 weeks waiting for my 2520 to appear) and on my buddy's old Ford 1500, all with absolutely no clearance issues. The hitch on the 2520 is advertised as cat 1, not limited cat 1 like many of the various sub-compacts. I've also heard that 2520owners with Deere I-match hitches are still having the rubbing (correct me if I heard wrong on this one).
Now to throw more fuel on the fire has anyone had these other annoying issues with the 2520:
1) #46BH footrests dig into the rear tires when mounting and unmounting the BH and only have about 1/8" clearance when operating. And yes my tires are in wide position.
2) Power-beyond connector bracket digs into the bottom of the BH seat. I have the newer notched bracket, but it still hits the bottom of the seat.
3) My tractor owners manual had a completely wrong procedure listed for changing the hydro oil and also the wrong oil capacity listed for the engine oil (4 qts is correct but lists 3 qts). Who knows what else is wrong in the manual. The dealer copied the correct Hydro changing pages from his manual, but didn't know if he could replace my manual under warranty:mad:
I work for another fortune 500 company (that makes office machines) and issues like these seem like they just shouldn't happen for a reputable company, but frankly I'm not suprised. Sadly, as an engineer now I see on a regular basis a lack of common sense, poor attention to detail, and sometimes just plain bad decision making. Sometimes I even see the dreaded "It's not our problem, someone else will have to figure it out". Problem is, my company is running out of "someones" to figure things out.
OK, off my soap box now. I'll be loading my 2520 on the trailer for a job this weekend. I'll try to fit in a stop at the dealer to see what their marching orders are.
/ Calling all 2520 owners #30
hemiguy said:
Hi all,
Hemiguy, here is the fix for your problems.:)
#1 yes my foot rest was hitting my tires too.
Took a band saw. took a hafe inch off each side.
same angle as factor cut. problem is solved....:)
#2 yes power beyond bracket was digging in the seat.
i took a ziz wheel on a air cutter , and cut a 1/2 by 1/2 L
on the left side of the bracket. clean and painted. looks like i
never touched it. seat dont hit no more.....:D
#3 yes the owners manual is crap. nothing is right.
i just did my 50 hour service and when i changed the oil and
filter it took 4 quarts even .
None of the fluid levels are correct in the book.
it takes usualy more than what it says. i think is all
based on a 2305 or something. I found if i dont like
something i just fix it my self. but i do understand your frustration...:(
fortunatly , i was a metal fabricator. so i can do all this stuff.
and someone who cant. always has to go to the dealer for a problem.
and thats a pain. then again, after spending $20,000 you would think
there would not be these little problems.
Chris....:)
/ Calling all 2520 owners #31
Thanks for the reply bz1, the two implements that I have is a MF plow and a JD back blade. Same problem, the pins cannot be moved to the inside. Both of these will fit my Ford 8N and Ford 1300.
Hemiguy, I too have the 46 backhoe that is tearing up the front tires. If you look in the parts catalog they have two 2520 mounting frames. A 4115 LATE VERSION/2520 EARLY VERSION and a 2520 LATE VERSION. The two have different subframes/mounts. I have the 2520 EARLY VERSION. When I turn the wheels all the way to the left or right the tires hit the subframe mounting bracket (even on level ground/in the garage). It´s chewing off about 1" of the outside edge of the lugs (R4s). I had my dealer file a DTEC 2 weeks ago and JD answer was smaller tires. The 2520 comes with 23 - 8.5x12 and they want to put 23 - 5.7x12. I measured the tread width on the 8.5x12 and it measures approx 7" and the 5.7x12 measures approx 4"? I told the dealer that I did not think that was the proper fix. I am waiting for a phone call back from a JD Supervisor.
As for hooking the backhoe up, I have found that if you extend the boom out straight and parallel with the ground, when you raise or lower the backhoe with the support arms the backhoe will move up and down evenly and is balanced. This will help with the tire clearance and putting the pins in the subframe mounts.
/ Calling all 2520 owners #32
A little off subject. I have less than 10 hours on my new 2520 and I can't see either the oil level or "bubble" in the sight glass. What I see looks like a verticel reddish colored disk. I added some oil (1 gallon) and still see no liquid. Could it have been that low fromt he dealer? Am I missing something?
Your thoughts.
/ Calling all 2520 owners #33
AKK, if it's red colored then I think you are looking right at the hydro fluid. It must be over filled and you just can't see the top of the oil. With my machine I can just barely see the top of the oil level. The oil is red and behind the oil is silver colored metal that will look red if you are looking through the fluid. I would start slowly draining fluid out until you see the top of the oil show in the sight window.
/ Calling all 2520 owners #34
Your thoughts.
You are looking at hydraulic oil,, check the level right after you start the engine with it running and you should see what it looks like with no oil in the sight glass.
/ Calling all 2520 owners #35
thx. I'll drain it down today and see what I get.
/ Calling all 2520 owners #39
Talked to the dealer today and Deere cleared the new 3PH arms at no cost. Thanks guys :)
/ Calling all 2520 owners #40
im glad they did the right thing :)
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
New/Unused Wolverine Sickle Bar Mower (A65583)
New/Unused...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
