Calculation help
/ Calculation help #1
Mysfyt
Platinum Member
NE Wisconsin
Kubota L3901
Need to know the deflection of 2-1/2" round steel bar, 44" long supported on both ends with 1000 lbs load in center. The bar is hardened to 100 ksi.
/ Calculation help #5
How is the end of the bar supported? Into a rigid structure (concrete wall or similar), or supported from underneath? It will make a pretty significant difference in the result.
Also the yield strength of the material (100 ksi), won't make a noticeable difference in the deflection. It will, however, affect the load which the bar will carry and still be able to return to its original shape when unloaded.
/ Calculation help
I'm designing a fork attachment for my tractor and item #1 is the bar in question. It will be supported by welded on collars to the side plates.
/ Calculation help #7
If it is like a typical forklift carriage, that bar dont really see a downward deflection, rather a forward deflection as the forks act as a lever to pry it out.
Depending on how far out on the forks the load is will change the deflection
/ Calculation help #8
On this one it would be interesting to see a force vector diagram on the tube at the center point.
/ Calculation help #9
LD1 is correct, that bar is subjected to as much horizontal force as it is vertical, if not more. You also need to define the width of the center support, in this case the two fork brackets, as well as how the two ends are supported including the span of the end supports like jb1390 noted. It's much more complicated than a simple deflection calculation.
/ Calculation help #10
2-1/2" round bar? That will be almost 60 lbs of steel... do you mean pipe? How about adding a center support and using 1 or 1-1/4 bar?
/ Calculation help #12
I think most forklifts do have a center support to. those that have the tube style forks like that.
No reason to have the left fork go right of the center support and vice versa
/ Calculation help #13
That's what I did when I built my forks. I've had all that my 3pt could carry on the forks (about 1800#) and nothing bent.
/ Calculation help
The center support is where the calculation is aimed at. I want to add a pair of cylinders to move the forks in and out with my third function and I figured it would be best to get the structural components established so I can place them accordingly. I agree with LD1 about the outward force vs the downward, but I was trying to keep it simple as far as the deflection calculations go. What I'm getting at is, if there was 1000 lbs on the forks as they are in the the image, would that be the maximum deflection on the bar? Or, let's say we just hung that weight by a chain in the center, what would the deflection be?
/ Calculation help #15
To get the moment of inertia, its (pi x r^4)/4
to get deflection its (W x l^3)/(48EI)
Where:
W is weight in pounds
l is length in inches
E is modulus of elasticity. (steel is 30,000,000)
And I is the moment of inertia calculated in the first equation
So: The radius of 2.5" is 1.25. so (pi x 1.25^4)/4 = 1.917
(1000# x 44"^3)/(48 x 30,000,000 x 1.917) = 0.030" deflection
/ Calculation help #16
It seems reality is more than a simple equation?
/ Calculation help #17
,,,,,,,,,,,,,,:thumbsup: ... [The amt of deflection the bar can withstand elastically.]
/ Calculation help
Where:
Thanks! Looks like I can proceed.
PORTA POTTY (A68842)
2016 Nissan Frontier Crew Cab Pickup Truck (A66736)
2016 Nissan...
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
1999 TRAILMASTER PUP TRAILER (A67714)
1999 TRAILMASTER...
PALLET OF FUEL TANK AND TOOLBOXES (A68842)
PALLET OF FUEL...
2013 MITSUBISHI FE 4X2 S/A 20FT BOX TRUCK (A69167)
2013 MITSUBISHI FE...
