Quote:
Originally Posted by CarlL View Post
Basically, you won't find all of these in any one ZTR.
Dang.
Then there is the question of size of mower 48", 60", 72"? There is also the issue of what the land and type of grass you are cutting.
60"
I tried a Kubota ZTR on my very bumpy property, after being told I could cut my mowing time in half compared to my old
B7100 with 60" MMM. ZTRs list very high mowing speeds. If I hadn't had my seat belt fastened, I would have been thrown off the one I tried, a number of times.
For cut, I would go with Scag or Exmark. For ride, I would go with Ferris or the try the new Scag Cheetah, with its fully suspended operators section. For engines, of course the Kubotas or the Cat diesels. However, be aware that the big diesels weigh a lot and can be a problem when the ground is not dry.
Very good info. Thank you. Thanks everybody for all the opinions & info.
CarlL's advice summarizes all that I concluded when researching ZTR's. I bought the "cadillac" Ferris 4500 diesel with 60" deck. Pro's: Ride (suspension), power, construction. Con's: diesel weight when ground is saturated, wide 60" deck scalps sharp hill crests when set to 3" or lower mowing heights. Perhaps a lighter gas engine Ferris 3000 series with 54" deck would have been optimum for my application. YMMV.
