CADDigger 608 Experances?
/ CADDigger 608 Experances? #1
wmgeorge
Ankeny Iowa
JD650
I know I have done some searching on this, but I'm trying to find out after you've got it done, how it worked out for you.
What does it weigh when you are finished? What bucket size did you build? Anything you would do different when building?
I've got a older 1981-82 John Deere 650 I'd like to use it on, only about 16 HP, but with the FEL and tire weights and all I figure it is about 2200 lbs.
To put things in perspective the original John Deere "B" only had 16 HP the later models made it up to around 25 HP before it went out of production. I think dad pulled a 2 bottom plow on his "B". BG in Iowa
213121 (A64276)
213121 (A64276)
Lesco 50Lb Push Spreader (A64557)
Lesco 50Lb Push...
2008 Nissan Xterra SUV (A64557)
2008 Nissan Xterra...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
PALLET OF CULTIVATOR PARTS & FERTILIZER APPS. (A64278)
PALLET OF...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
