cabs and ROPS
/ cabs and ROPS #1
jimg
Perhaps this is obvious but I'll ask anyway. In all of the literature I've poked thru and all of the cabs I've looked around in I can't find anything about built-in ROPS. I'm sure they must be there though....right?
/ cabs and ROPS
OK, so is that something molded into the fiberglass (or whatever the cab is made of) or is the cab 'free standing' and able to guard on its own?
/ cabs and ROPS #4
The cab has four metal posts to support the cab. They are just covered with plastic or sound damping material on the inside. It's just like a four pilar rops/fops with more creature comforts.
/ cabs and ROPS
thanx
/ cabs and ROPS #6
No problem. I think what I said is right. I don't think our government would allow a tractor company to build a cab with out some sort of rops built in with at least 2 steel posts. If it rolled the person would be killed pretty quick if it was a big tractor.
/ cabs and ROPS #7
What about older tractors. In about a year or so, I'll be looking for my next tractor for our growing little agricultural fleet, and it'll have a cab, and probably no newer than the 60's or maybe early 70's.
/ cabs and ROPS #8
You will have to examine the cabs on older tractors for strength. Some of those were just cabs with no real frame in them.
/ cabs and ROPS #9
Also seat belts were not manditory then and now they are. The cab and rops needs to be OSHA certified and stuff like that I believe. Look on the roll bar or cab on a new tractor and you will see if it's certified or not.
/ cabs and ROPS #10
Hey Rich,
If I was you and going for a cabbed tractor,look for one with a factory installed ISO type cab. Best ones off the top of my head in the 60s that were available over here came from Case and Zetor. Massey had some that were not too bad. The other companies used aftermarket suppliers. Most of the aftermarket cabs were great for sound amplification,not deadening..... By the mid to late 70s the US based manufacturers had embraced ergonomics and factory cabs.
/ cabs and ROPS #13
Hi,
Also, when you find a tractor you like, take a test drive at max RPM. Sometime in the 1970's all tractor companies had to build cabs with a noise level no higher than 90 db. Hope this helps
Will
/forums/images/graemlins/grin.gif
