Cable size
   / Cable size #1
daedong
Veteran Member
South Australia
I have a large inverter on my houseboat. I have run (Twin) double 00 cable to the battery box. in the box i want to put a fuse block however the fuse block i have will only take one cable would it be acceptable to reduce back to one cable before going into and out of the fuse block.
   / Cable size
Ron,
The fuse i have is very similar to that one .
My inverter required 0000 cable which i was unable to get so as ran TWO 00 cables to get cable capacity. However my fuse will not accommodate two cables so i wondered if I could reduce back to a single cable for about 2 inches either side going in and out of the fuse
   / Cable size #4
Reducing from two 00 to one will make the single 00 cable the smallest point in your wiring. You will not be able to draw enough current through a single 00. Other than cost. Why not use 2 fuse holders. One on each 00 line. Each holder would have a fuse 1/2 total amperage.
What size inverter do you have? My 5000 watt inverter has 00 for a 10' run.
   / Cable size #5
Ron H. is right, you need 2 fuse blocks.
If you use 2 fuse blocks be sure you use fuses rated for 1/2 the amperage load.
Bill Tolle
   / Cable size #6
I think they are giving you some good advice on using 2 fuse blocks.
2011 GMC Acadia SLE SUV (A53424)
2011 GMC Acadia...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
