Cabbed JD 4520
/ Cabbed JD 4520 #1
KRH
E\'ville, NY
JD 5225 MFWD w Power Reverser; 2010 JD 110 tlb; 2007 JD 4520
Looking at a used 2007 4520 with a cab. Lever to raise and lower the rockshaft arms will move only slightly. The shaft that goes into the rockshaft housing will not move/turn. The cable appears to be free and has no kinks or sharp bends. It will move. From sitting all winter could some corrosion build up between the shaft and the rockshaft cover not allowing it to move? Or could it be something more serious. BTW, they said the 3pt hitch worked fine before.
Thanks.
/ Cabbed JD 4520 #2
A couple of years ago I had problems with my rockshaft control and had to remove the cover and reconnect the linkage. While it was simple to fix and hasn't been a problem again since yours may have damaged parts. Just something to consider if you buy as is. Removal and replacement took me about 2 hours or less without any special tools and I was able to unbolt and lift the cover off by myself easily. That was on my 4520 cab 2009 and I don't think a 2007 would be different.
/ Cabbed JD 4520
Thanks!!!! Did your lever still work after the linkage came loose???
/ Cabbed JD 4520 #4
The lever worked and rotated, all the external linkage was okay. The internal parts came loose and had to be reassembled. One of the bolts fel into the sump of the axle and I retrieved it with a magnetic stick.
/ Cabbed JD 4520
Good to know!!! Thanks for the information!!!
Willmar 4550 Wrangler Articulating Loader (A63118)
Willmar 4550...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
2017 Unverferth 1245R-35 Rolling Harrow (A63116)
2017 Unverferth...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
