Cabbed HVAC Controls
/ Cabbed HVAC Controls #11
Have you tried to turn the Heater on now that you have that apart to see if it moves at all? I'm assuming you need to get to operating temp.
Yes, got the tractor up to temperature and it blows heat with the valve manually opened. I still didn't hear/see any movement when adjusting the blend control or heater switch. I tried to move the coolant valve actuator by hand and it didn't want to move. I'm not sure if it is frozen up and that is my problem or if it's the gearing that won't let me move it without applying lots of pressure. I'm starting to suspect that the actuator is the problem and not the control panel. Any ideas on how to test the actuator?
/ Cabbed HVAC Controls #13
Can you disconnect the electrical plug and trace it back to the controller?
Then see if it is coming from the temperature rheostat or the switch or possibly both?
Then check voltages with the various controls?
/ Cabbed HVAC Controls #14
I noticed in one of the pics the controller was a Doowan;
Doowan Parts Buy Auto Parts
Possibly these people could help with controller details
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
2016 Bobcat T650 (A60462)
2016 Bobcat T650...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
429981 (A61165)
429981 (A61165)
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
