Cab owners - several questions
/ Cab owners - several questions #22
/ Cab owners - several questions #23
Those are pigtails. The connector already has wires in it.
The ones I posted are the kit to assemble the connectors directly onto your new lights wires. Instead of having to splice wires to wires. :thumbsup:
[/url]LED light upgrade by Jason, on Flickr[/IMG]
/ Cab owners - several questions #24
Excellent! Thanks! Just ordered 4 connectors and total was $12 plus $2.61 Shipping. Same on eBay we’re $13 each.
I received the four connectors from Formula J87 and can confirm that the 862 plug directly into the cab side work light plugs.
Wire Harness Light Bulb Male Pigtail Plug Connector S 862 H27 PGJ13
Order from his web site above as they were $3 each plus shipping of $2.61 so ..... $14.61 Total for the four connectors. If you order them, from Formula J87, they are $13.00 each but free shipping.
Thanks for finding them drewmon.
/ Cab owners - several questions #25
I’m okay with pigtails JL. I make good mechanical connection, solder, then heat shrink tubing over the connection to keep out water. Others may prefer your connectors, either way we have two good solutions to replace work lights on LS cabbed tractors.
/ Cab owners - several questions #26
Glad they worked out for you. That was fast shipping. Wish I had this info when I was researching. Took me a while to find the right connector.
/ Cab owners - several questions #27
I’m curious as to how you did find the right connector? Amazing!
/ Cab owners - several questions #28
It took a few tries to find the right one. I used the info from other members, but that sent me down the wrong path. I ended up taking the bulb from the tractor light to an autoparts store and basically reverse engineered the socket needed. from there. I bought a few from ebay before finding the correct one.
4 ROW CULTIVATOR FRAME (A60430)
4 ROW CULTIVATOR...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2020 FREIGHTLINER...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
