Cab on a BX24
/ Cab on a BX24 #1
bird1968
Canada NB
BX24 after years of BX22
I got my old cab from the BX22, (Curtis, which I had to modify for the BX22) & remodified it to fit the BX24. I bit more work this time around.
I'm not sure if anyone is making a factory one for a BX24 yet, but here my version.
Hope this helps someone.
Richard
/ Cab on a BX24 #2
looks pretty shiney! The same cab companies still fit the same way!
/ Cab on a BX24 #3
Looks great. Share some more pics (especially where it meets the engine cowling - both inside and out)
/ Cab on a BX24 #4
If that shiny silver plate on the front was orange, it would look almost factory. Good job :)
/ Cab on a BX24 #5
I like that diamond plate. How's the grapple project going?
/ Cab on a BX24 #7
Richard
Wow, looks great!
CabDepot makes them for BX series up to BX 23.
Sims Cab Depot - Kubota Sub-Compact Tractor Cab Enclosure - Models: BX1500, BX1800, BX1830, BX22, BX2200, BX2230, and BX23
Under "upcoming products" They state that one will be available this year for BX24 (TBD 2007)
/ Cab on a BX24 #8
I've often wondered if it would be possible to replace my BX 23 ROPS with a BX2250 ROPS bar for the winter, so as to allow the use of a cab, since the backhoe would be off for winter anyway...
Nice work Richard. You must have a cool workshop...
Pat
/ Cab on a BX24
I may have to paint it; it's hard to take a picture & the deers are always getting in the way! :)
Here a pic, with the door on.
/ Cab on a BX24
I'm not 100% finish, I need to pickup a few rubber molding, which will seal it all up.
/ Cab on a BX24
I'm still picking up a few parts for the grapple, but I'm finihing the Ripper/plow/trenching/3PT 4in1 project. I got 3 of 4 finish. I should have the adater kit for the 3Pt finish, early next month. After that it's grapple time :)
This thing is amazing for trenching!
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
ASSET DESCRIPTIONS & CONDITION (A59914)
ASSET DESCRIPTIONS...
