Cab mirror [ Engineer42's fault ]
/ Cab mirror [ Engineer42's fault ] #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
Due to Engineer42 posting about his rear view mirror, and him planting a seed into my pea sized brain... I just finished putting mine in. So, blame him, not me... if you can't sleep at night.
I bought the mirror on Ebay [ you can get them on Amazon, too. search for CHUPACABRA mirror ] and then made some brackets for it out of aluminum. I screwed the brackets on using Stabilicer [ Stabil Icer strap on ice cleats, the hardened replacement screws for same ] screws because they were short, stubby, and made for rubber or plastic with a coarse thread. Drilling the holes was a hoot, knowing about all the expensive coils and things located just behind the headliner. I drilled carefully, and only found one hole on the bottom left that I was concerned about a spaced it out with a 1/8" plastic washer to add more clearance to what ever was back there. Also a picture of my voltage monitor I have on all my equipment [ Motorcycle ATV Universal Waterproof LED Battery Voltage Meter Indicator Pad 12V | eBay ] to make sure my fan belt is not slipping some whilst snowblowing. And a picture of the right pillar mode where my switches are. Life is GOOD...!!!! :)
/ Cab mirror [ Engineer42's fault ] #2
Lol, yeah that’s my fault. I’m sure you had already pondered a mirror for that spot. Looks good. I like the rockers too.
Tom
Tom
Yes, but it sure feels better when you look at your credit card bill if you can push the blame elsewhere. But I appreciate the great idea about the Chupacabra mirror. I was looking at others but this one gives you a more panoramic view.. :)
/ Cab mirror [ Engineer42's fault ] #4
I can understand that. I hate spending money myself but figured this is a good $25 investment if it keeps me from tapping something. Mine isn’t Chupacabra brand, but works well.
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
Four (4) TAG Excavator Couplers (A65640)
Four (4) TAG...
Kubota Zero Turn Lawnmower (A65579)
Kubota Zero Turn...
2016 Husqvarna DRT 900H Tiller (A66408)
2016 Husqvarna DRT...
Hercules Rustic Gun Safe Holds 20 Guns (A65583)
Hercules Rustic...
JMR 4X8 WORK BASKET (A64553)
JMR 4X8 WORK...
