Cab heater problems
/ Cab heater problems #1
patioh
ontario
international 444
Installed after market heater in cab .Where is the best lacations to hook up heater hoses on engine (international 444 diesel) .I tried fitting at thermostat housing fittng and temp sensor tee ,should i come off water pump fittng and drain port?
/ Cab heater problems #2
General rule of thumb for heater hoses: one port in cylinder head or thermostat housing(whatever is available with least difficulty) for source of hot water. Return or suction hose should go to inlet side of water pump. There may be a threaded port in the tube the lower radiator hose slips onto, which would be convenient. If not, you might fabricate something to insert into the lower rad hose to provide a port. Not the best answer, but a possibility to consider.
Thanks I'll give it a go
International 574 Loader Tractor (A66285)
International 574...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
Stout Buckets 66-9 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets 66-9...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
