cab building ?
/ cab building ?
Hello Rob...nice work so far on your cab. I was wondering if you could tell me how you got the nice curved edge on your door where it follows the contour of your fender? Also, could you show a close up of your door hinges and how you constructed them? Thanks.
Thanks for the nice words. I made the curved sections with a very simple home made bender. I used a pine board cut in a a curved shape and bolted to a flat surface. I then put a bolt 2" from the end and used it to hold the tubing from moving. It worked ok but was not a simple one bend deal. I had to make mutiple trips trying to get the bend just right. the real hard part was geting the door shaped close to the same. When I get a chance I will take a picture of the bender and also the door hinges.
Rob
/ cab building ? #22
NH Rob,
Cab build looks really good.....can't wait to see the final pix.....You'll be needing it when the Lancaster snow flies.....Any snow still left from last weekend..??
I'll be going up with my houndley mutleys for a running-harvesting session this Sat up your way....
Did you do anything with the "$7 seal" problem on the drive shaft..??
Bill
/ cab building ?
NH Rob,
Bill
Final pic on the cab is still a ways out. I have not done a darn thing on it in so long. I bought a sand blaster to clean the rust off of the window frames but have been to busy to do anything. I still need to put the heater in and a block heater but as you mentioned i still need to fix that darn seal and that means the cab needs to come off. I am planing on fixing the seal myself. I have been thinking I would do this some time this winter and just put the plow back on the jeep for a few weeks. Kinda silly with the great weather that we have had this winter and I still have not gotton it fixed.
Rob
/ cab building ? #24
I made this cab for my 2210 jd 2 years ago them when I got my 2305 I moved to that tractor radio heater wipers lights works great.
/ cab building ?
Ok I finally took the time to take pictures of my door hinges. They are nothing special. I used 3/8 dia long nut conectors and drilled them out. I then used a combination of angle iron and flat steel pieces to get them welded to the frames. I welded 3/8 solid shaft for the door pins. as you can see I need to get them sand blasted and painted. I also included a picture of the home made bender that I used. I had it bolted to my utility trailer at the time I did the bending.
On a side note we had freezing rain and then some snow the other day and I left the tractor outside durring it all. Today I needed to use it and the hood was fairly froze but the cab windows where all clean and the cab was a little warm just from the sun shine. It was great no frozen seat and all the controls where not built up with snow.
Rob
/ cab building ? #27
I like the hinge arrangement, is that for taking them off during the "Construction Season"......
:laughing::laughing:........A little inside joke here......Some say we have two seasons in New England......Winter and Construction Season......:laughing::laughing:
2022 John Deere R4023 (A64119)
2022 John Deere...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
2014 Chevrolet Traverse Multipurpose Vehicle (MPV) (A62613)
2014 Chevrolet...
2018 John Deere 470G Hydraulic Excavator (A61572)
2018 John Deere...
Landhonor SGB-11-72W, 72" Grapple Bucket  (A62679)
Landhonor...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
