Cab alarm too loud
   / Cab alarm too loud #1
trlbrkr
New England
02 NH Tn 75D-06 Kubota 105X-14 Toolcat 5600G-13 Kubota Excavator U35
Not sure why Bobcat has an alarm for turning the key but this new machine is loud. I have unsuccessfully tried to find the alarm under the dash to muffle with tape or if possible disconnect. Appreciate suggestions.
   / Cab alarm too loud #2
The same alarm is used if/or when a critical code/problem arises so it is loud enough to here when engine is running, if you do locate and muffle the alarm you might not be able to hear it should engine or hydraulics start to overheat or loose pressure.
You should be getting a very quick (2 or 3 beeps, don't remember exact number) when key is turned. This just verifies all electronic communications have been made. If you are getting a constant alarm there is some type of problem and you need to push the "HOLD for Codes" button to read the code and see what is going on.
The alarm is located on fuse bracket near accelerator.I wrapped it in seat repair material and it is a 100% better. Alarm is number 2 on diagram below
   / Cab alarm too loud #4
Thanks, I will muffle ours a little. Still need to hear the low fuel alarm, it saved me from running out today while mowing. :thumbsup:
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
UNUSED FUTURE 20' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 20'...
UNUSED SDLANCH SDLL50 STAND ON SKID STEER (A57192)
UNUSED SDLANCH...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
