Cab AC
/ Cab AC #1
Oiltech
La
Kubota L3540HSTC, M7060HDC-12, ZD331-72, Bobcat E42
The temperature of the air coming out the vent on my L3540 is 48.6 degrees. The temp of the air on my M7060 is 55 degrees. If my memory serves me right it should be 48 degrees?
/ Cab AC #2
Maybe you could clean the condensor and radiator if it isn't performing to your expectations. It never hurts.
/ Cab AC #3
Ditto on cleaning cond. & rad. plus blow out both AC filters if similar to a M7040
/ Cab AC #4
Also check your compressor belt tension. When i bought tractor used it wasn't blowing cold after it warmed up. Checked and it must have had close to 1 1/2" play.
/ Cab AC
I checked the screen and coil which is clean, the tractor is 6 months old and hasn't been in dusty service or where there is a lot of debris in the air like from bush hogging. It cools but only if it stays on maximum with recirc on. I will have the dealer check it. I think it probably needs a squirt of Freon to get it to perform at maximum.
Thanks for the suggestions
/ Cab AC #6
On a automobile anything below 50* is acceptable.
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
30x57 Welding Table (A65640)
30x57 Welding...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
HYUNDAI HL770-9A WHEEL LOADER (A65053)
HYUNDAI HL770-9A...
