C50 & 50HL Loaders
/ C50 & 50HL Loaders #1
Reg
Elite Member
I have a 50HL {Humpolec} loader and some time ago it lost the float detent.
That is to say I can float the bucket, but the joysick won't lock in the forward position, so I have to lean on it continuously.
I am looking for an adjustment procedure - something that takes account of wear.
This morning I followed the installtion instructions and mimic'd a joystick install.
Page A-10;
I removed bolt (D), loosened the allen bolts holding flanges (M), loosened lock nuts (X) , locked the joystick with lock ring (R) and turned each of the two sleeves (Y) so that bolt (D) would pass through the lock grooves (U) in each of the cable outer ends.
I think this sets the cable outer sleeves to the right length, by doing it again I think it should have taken up any wear, stretch, compaction of outer cable & whatever all else.
Then I put it all together, snugged it up, etc.
There is barely a noticeable difference, other than I don't have to push slightly left as well as forward to get float.
It still doesn't detent into float.
Any help would be greatly appreciated - I know it COULD BE the valve itself, but don't want to tear into that unless/until I have to.
I can live with this and have for a while, but it IS starting to get to me (-:
I think this is a general loader/joystick/hydraulics question, though the references in the procedure I quoted above are specific.
For the joystick and cables this seems to be the parts supplier;
:: INDEMAR INDUSTRIALE ::
so that may be useful at some point for someone with cable problems.
Not sure who does the valve body itself, still searching around on that.
Anyone know anything general about float detent ?
I also posted in the hydraulics forum, so if anyone HERE has similar problems in the future it may be worth reading whatever this thread;
http://www.tractorbynet.com/forums/hydraulics/273159-loader-float-detent.html
leads to.
So far just the general info about how Prince brand directional valves do detenting, which is helpful because I hadn't read my Prince rear outlets booklets
in 5 or 6 years.
2022 BIG TEX 22GN-35BK+5MR T/A 48FT GOOSENECK TRAILER (A59909)
2022 BIG TEX...
2018 BOBCAT S470 SKID STEER (A62129)
2018 BOBCAT S470...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2014 JEEP GRAND CHEROKEE (A62130)
2014 JEEP GRAND...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
