Bypass Safety Switch on BX22
   / Bypass Safety Switch on BX22 #1
DOC4444
Massachusetts
Kubota BX22
Sorry, tried searching, but to no avail. For a while now, the tractor has occasionally not cranked without moving the gear lever in and out of low and high a few times and then returning to neutral. However, today, no amount of fiddling will allow it to crank. (Started and ran fine for 30 min. Shut down for 10 min, then would not crank.) I believe there is some sort of switch to prevent cranking when in gear. I have heard of bypassing it.
Can someone please help with where the switch is located and how to bypass it?
THANKS!
DOC
   / Bypass Safety Switch on BX22 #2
I don't have the 22 but the 2200
I had the same problem. I was able to fix it when I followed that shift level down to the neutral switch and found dirt and debris by the button that prevented from moving when moving that lever.
   / Bypass Safety Switch on BX22 #3
DSC_5878.jpg I wasn't home earlier to get pic. Sorry didn't take pic after I cleaned it. If you look in that area and move that lever you'll see the switch. Dan.
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2025 REDELIFT CPD25-XD4 FORKLIFT (A52576)
2025 REDELIFT...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
2012 Caterpillar AT1055E Track Asphalt Paver (A51691)
2012 Caterpillar...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
