BXpanded Hydraulic Pressure Test Kit
/ BXpanded Hydraulic Pressure Test Kit #21
Does this kit show you where the pressure relief valve is on the BX 60 series? I already have a pressure gauge from when I had a JD and my BX tested out a year or so ago right at spec. But if/when I do need to compensate for an aging relief valve spring, I'm not sure where the little sucker lives on my BX. Anyone know?
/ BXpanded Hydraulic Pressure Test Kit #22
Why not make your own for $40.04? Try Discount Hydralic Hose.
Parts:
701-04-04S | 1/4" Female Coupler x 1/4" NPTF Female (Steel) 8.32 (Loader)
702-04-04S | 1/4" Male Coupler x 1/4" NPTF Female (Steel) 4.07 (Remotes)
AFC-3M-25 | Bottom-Mounted Pressure Gauge, 0 to 3,000 psi 17.50
Shipping USP $14.15
Allows you to check either male or female fittings. Shims are $.35 at Messick's and come in different thicknesses (.01mm .02mm and .04mm). I think pressure boost is 39 psi/.01mm shim.
Great info - thanks! I ordered today
/ BXpanded Hydraulic Pressure Test Kit #23
Code54
My hyd pressure was 1625 psi. Kicked it up to 1740 psi. Was afraid to go too high.
LA243 loader max is 1778 psi.
BX2660 spec is 1780 - 1840 psi. I checked at rear remote at max speed and fluid hot.
CHD
On BX2660 the pressure relief is the lower nut on the left of the pto guard. Not the nut above that looks like some kind of cap. Don't know if the BX1860 is the same.
/ BXpanded Hydraulic Pressure Test Kit #24
BTW I messed up earlier on the shim thicknesses. Should be .1mm, .2mm and .4 mm. Sorry :confused3:
Jim
/ BXpanded Hydraulic Pressure Test Kit #25
Jim
No problem.
Just glad to have found a less expensive source
Thanks again
/ BXpanded Hydraulic Pressure Test Kit #26
CHD
Thanks YJ - will have a look next time I'm out in the shed. I would guess all the BX's are the same regarding placement of the relief valve.
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
Beverage Truck Body (A64556)
Beverage Truck...
2012 Freightliner FLD120 Ambulance (A64556)
2012 Freightliner...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A64553)
2025 GIYI GY-P45...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
