BXPanded bucket teeth
/ BXPanded bucket teeth #1
biggziff
Upstate NY
2015 Kioti CK4010HST
Those of you who have these...can you still use the bucket for things like snow removal, back dragging, etc. with them attached?
/ BXPanded bucket teeth #2
Yes for backdragging and it will also protect against wear on your bucket edge. Snow removal I'm not so sure about. We don't get snow here. However, the under edge of any toothbar has a curved piece of steel where the bar attaches to your bucket and several 'hooks' that clip into the bucket edge, so they will scrap the ground before the leading edge of the bar touches the ground. I would think that if you are scraping pavement or concrete you'd want to remove the toothbar and put on an edge guard. The good news is that the removal of a toothbar is a 5 min or so operation. Remove a bolt on each end of the bucket and lift it off. They are heavy so when lifting use your legs and not your back. Ask me how I know that! It is a superb product and will add a lot of strength to the lower edge of your bucket. Go to any rental place and look at the buckets on FEL. Most will be shaped like a smile instead of straight. This comes from using your bucket as a pry bar, something we all do, but rental equipment gets the worst abuse. The toothbar helps maintain your bucket's integrity. I have used the traditional forked toothbar and the bxpanded and much prefer the latter.
/ BXPanded bucket teeth #3
If you have a paved surface you're removing snow from I'd recommend removing it. If you don't you'll scratch and dig it up.
As mentioned it only takes minutes to remove and install.
2201SFL (A64553)
2201SFL (A64553)
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
Salt Dog by Buyers Slide in Spreader Box 10' (A62679)
Salt Dog by Buyers...
213324 (A64279)
213324 (A64279)
