bx2750d set screw threads
/ bx2750d set screw threads #1
PeterK
Central Maine
Kubota BX24 TLB
I went to oil the chain on my blower after a good workout over the last couple of days and noticed that the upper chain gear is missing both set screws. No wonder I suddenly started breaking shear pins on the fan.
I looked down the threaded holes with a flashlight and can see a shiny spot from previous pins so I know they're supposed to be there - also the gear moves back and forth a bit with a screwdriver.
Can anyone help me with the thread size/type. I've tried 5/16-18 and it starts to thread then stops. Also tried an 8mm-1.25 bolt. Maybe a tapered pin? Allen head set screw?
/ bx2750d set screw threads #2
Can't remember if it is a keyed shaft. It is keyed, then the set screw will just keep the key in place. You might want to take the gear off and run a tap through first. Should be std thread. Ordinary tap will bottom out if you leave it on shaft.
Parts diagram says 2 pc. They are 5/16 - 18 X 1/2"
Jim
Thank you Jim. My manual states "obtain locally" but I was leaning towards 5/16-18 vs metric.
New ones are going in with loctite, like they should have been to begin with.
Thanks again.
Oh. One set screw to hold the key in and one 90 deg on the shaft.
/ bx2750d set screw threads #5
PeterK
You got me to check mine tonight. They were tight. :thumbsup:
/ bx2750d set screw threads #6
Noticed that mine were way loose in the fall.
The key was walking it's way out.
2015 KENWORTH T800 TRI-AXLE (A65643)
2015 KENWORTH T800...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
Woods Brushbull BB60 3-Pt Rotary Mower (A66285)
Woods Brushbull...
2017 Link-Belt 350X4 Hydraulic Excavator (A64553)
2017 Link-Belt...
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A65563)
2021 Big Tex...
