bx2750d set screw threads
/ bx2750d set screw threads #1
PeterK
Central Maine
Kubota BX24 TLB
I went to oil the chain on my blower after a good workout over the last couple of days and noticed that the upper chain gear is missing both set screws. No wonder I suddenly started breaking shear pins on the fan.
I looked down the threaded holes with a flashlight and can see a shiny spot from previous pins so I know they're supposed to be there - also the gear moves back and forth a bit with a screwdriver.
Can anyone help me with the thread size/type. I've tried 5/16-18 and it starts to thread then stops. Also tried an 8mm-1.25 bolt. Maybe a tapered pin? Allen head set screw?
/ bx2750d set screw threads #2
Can't remember if it is a keyed shaft. It is keyed, then the set screw will just keep the key in place. You might want to take the gear off and run a tap through first. Should be std thread. Ordinary tap will bottom out if you leave it on shaft.
Parts diagram says 2 pc. They are 5/16 - 18 X 1/2"
Jim
Thank you Jim. My manual states "obtain locally" but I was leaning towards 5/16-18 vs metric.
New ones are going in with loctite, like they should have been to begin with.
Thanks again.
Oh. One set screw to hold the key in and one 90 deg on the shaft.
/ bx2750d set screw threads #5
PeterK
You got me to check mine tonight. They were tight. :thumbsup:
/ bx2750d set screw threads #6
Noticed that mine were way loose in the fall.
The key was walking it's way out.
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Allis Chalmers 1200 Field Cultivator (A66408)
Allis Chalmers...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
Swict 66in Bucket Skid Steer Attachment (A64553)
Swict 66in Bucket...
