Snow Bx2750 Rebuild
/ Bx2750 Rebuild #1
cubowner
Kubota BX24
Last winter I purchased a BX2750 blower that was in rough shape. Brackets bent bearings worn and paint chipping off. I used the blower last winter and now it's time for a complete rebuild. So I started the project this week so I can get my blower ready for winter. I stripped down my Kubota BX2750 snowblower to just a shell. I then stripped any loose paint sanded and then primed the blower. I then coated it with 5 coats of paint. Now I am replacing all bearings and bolts. Will keep everyone posted with progress
/ Bx2750 Rebuild
Well here is the rebuilt blower. I finished painting an replacing all worn parts and decals. Next I will be upgrading the chute controls.
/ Bx2750 Rebuild #6
Excellent job. That blower will give you many more years of service. Do you have the make and part numbers for the actuator and motor for the chute? I would love to add those to mine.
/ Bx2750 Rebuild
Where is the best place to mount the switches for the chute rotation and up and down control?
/ Bx2750 Rebuild #9
Cub,
Do you have a cab? If not you may want to consider getting and or making one. Snow blowing without a cab is NOT fun! My 1st cab was a golf cart cover over a copper pipe skeleton I made up. My switches are mounted in a box in the cab. My lights, window fan, yellow roof hazard light, and heater fan are all in the same box. Here is a post I did on my cab mounting process.http://www.tractorbynet.com/forums/kubota-owning-operating/91339-getting-bx-ready-winter.html
Here is the golf cart cab thread http://www.tractorbynet.com/forums/kubota-owning-operating/19837-bx-2200-cheap-cab.html
/ Bx2750 Rebuild #10
That's where I put my chute deflector switch. You could also put the rotation switch in there.
All controls for blower in one place
/ Bx2750 Rebuild
Where did you get the switch box from
/ Bx2750 Rebuild
What did you make it of? And where did you find the switch? All I could find is regular dpdt toggle switches.
/ Bx2750 Rebuild #14
Used 1/8 plate steel
(Approx dimensions 2"x1"x1")
A 1/4" tubing? By about 1" welded to 1/8 box
A power window switch from any car (wreckers)
These switches will take greater amperage without relays
GREAT PLAINS 2400 TURBO CHOPPER (A64278)
GREAT PLAINS 2400...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
3PT SPRAYER RACK (A64278)
3PT SPRAYER RACK...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
2022 EZ-GO ELITE...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
