Ballast BX2670 Tire ballast in warm climate
   / BX2670 Tire ballast in warm climate #1
cmugler
santa barbara, ca
kubota l2800
I am in southern california where it never freezes, do I need to add anything besides water to add ballast to tires and is it acceptable to do just the rear tires? Thanks BX2670
   / BX2670 Tire ballast in warm climate #2
Water is OK, but adding a gallon of antifreeze in each tire for the anti corrosive properties should go a long way to preventing rust on the inside of the rim.
   / BX2670 Tire ballast in warm climate #3
Growing up in AZ desert, we only ever loaded tractor tires with plain water.
   / BX2670 Tire ballast in warm climate #4
You can add water or any fluid. The difference is the lbs per gallon!
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2016 Case CX55B (A55973)
2016 Case CX55B...
2017 FREIGHTLINER CASCADIA SLEEPER (A57880)
2017 FREIGHTLINER...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
