Ballast BX2670 Tire ballast in warm climate
   / BX2670 Tire ballast in warm climate #1
cmugler
santa barbara, ca
kubota l2800
I am in southern california where it never freezes, do I need to add anything besides water to add ballast to tires and is it acceptable to do just the rear tires? Thanks BX2670
   / BX2670 Tire ballast in warm climate #2
Water is OK, but adding a gallon of antifreeze in each tire for the anti corrosive properties should go a long way to preventing rust on the inside of the rim.
   / BX2670 Tire ballast in warm climate #3
Growing up in AZ desert, we only ever loaded tractor tires with plain water.
   / BX2670 Tire ballast in warm climate #4
You can add water or any fluid. The difference is the lbs per gallon!
2017 Ford T350 Van (A55973)
2017 Ford T350 Van...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2016 Ford F350 (A55973)
2016 Ford F350...
