BX2660 won't start, probably electrical?
   / BX2660 won't start, probably electrical?
Got the shop manual. Sadly, it has VERY little about the electrical system beyond simple schematics. Also, very few test procedures until you get into the engine guts section and there it has a little bit. Kinda of a sorry "shop manual."
   / BX2660 won't start, probably electrical? #32
Your 13 ga wire is only good for about 15 amps it used to be used
for wire for electrical outlets in homes but they switched to 12 ga
willy
Ok, here's what happened. I noticed that the starter was not jumping out (engaging) every time. Bad sign, bad juju. Even though the battery tested fine at a battery shop, turns out it's voltage was fine but just no load carrying capacity (even though the shop's tester showed it was. <sigh>) Took the starter to a car electrical shop and the guy tested it (our of circuit, of course.) He noticed that engagement was intermittent, too. So, I asked him to fix it. He did and it only cost $120. Starting was still very anemic, so broke down and got a new battery. Another $120. However, she starts and runs fine now! It certainly didn't hurt that I had cleaned all the contacts until they were all shiny. :) Thanks for all the advice, guys. Will take 4 months to financially recover but she works again! Yay.
   / BX2660 won't start, probably electrical? #34
I missed this when you first posted this but as I read through this I kept asking myself did he ever get a new battery? It seems like most of the time it’s just the battery. Glad it’s fixed and I’m glad you came back to tell us the fix.
PALLET OF TILE (A58374)
PALLET OF TILE...
EVINRUDE OUTBOARD MOTOR (A58374)
EVINRUDE OUTBOARD...
2014 Freightliner M2 106 AWD Altec DM48BTR Insulated Digger Derrick Truck (A55973)
2014 Freightliner...
2016 Morbark Chipper (A55787)
2016 Morbark...
New/Unused 13ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 13ft X...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
