Bx2660 engine oil capacity 3.7 qts.?
   / Bx2660 engine oil capacity 3.7 qts.? #1
kylied
Just did my 50 hr. engine oil and filter change, the manual says it will take 3.7 qts. of oil with a filter change, thats what I put in the engine, but on the oil dipstick it shows that its low, its just a bit past the half-way mark, so I could maybe add about 4 to 8 ounces to put at the top mark, I ran the tractor for a few minutes and let it cool down, still shows as I described above, dipstick is fully seated when I remove it and check it, anybody ever encounter this??
   / Bx2660 engine oil capacity 3.7 qts.? #2
My 23 has the same issue. It appears that the manual is wrong. I always buy one extra quart....just top it off and forget about it.
   / Bx2660 engine oil capacity 3.7 qts.? #3
My BX2660 is the same and on all my tractors I just add until I get the level right.
Thats what I'll do is just top it off, but wouldn't you think that the manual would get it right and list the proper capacity?
   / Bx2660 engine oil capacity 3.7 qts.? #5
I don't think the manual is correct with any of the fluids on my BX25. ie... front axle, transmission.
   / Bx2660 engine oil capacity 3.7 qts.? #6
Yep, you would think so.
28013 (A50322)
28013 (A50322)
Pallet of (4) 10 Lug Misc Wheels (A51573)
Pallet of (4) 10...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
2012 Mack CXU613 Sleeper Truck, VIN # 1M1AW07Y3CM018973 (A51572)
2012 Mack CXU613...
2003 Pace American Trailer, VIN # 4FPW540373G068816 (A51572)
2003 Pace American...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
