Bx2660 engine oil capacity 3.7 qts.?
   / Bx2660 engine oil capacity 3.7 qts.? #1
kylied
Just did my 50 hr. engine oil and filter change, the manual says it will take 3.7 qts. of oil with a filter change, thats what I put in the engine, but on the oil dipstick it shows that its low, its just a bit past the half-way mark, so I could maybe add about 4 to 8 ounces to put at the top mark, I ran the tractor for a few minutes and let it cool down, still shows as I described above, dipstick is fully seated when I remove it and check it, anybody ever encounter this??
   / Bx2660 engine oil capacity 3.7 qts.? #2
My 23 has the same issue. It appears that the manual is wrong. I always buy one extra quart....just top it off and forget about it.
   / Bx2660 engine oil capacity 3.7 qts.? #3
My BX2660 is the same and on all my tractors I just add until I get the level right.
Thats what I'll do is just top it off, but wouldn't you think that the manual would get it right and list the proper capacity?
   / Bx2660 engine oil capacity 3.7 qts.? #5
I don't think the manual is correct with any of the fluids on my BX25. ie... front axle, transmission.
   / Bx2660 engine oil capacity 3.7 qts.? #6
Yep, you would think so.
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
INOP/NON-RUNNING 2008 International 7300 Truck, VIN # 1HTWAAAN78J690166 (A51572)
INOP/NON-RUNNING...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
