bx2660 bushhog squealer leaves strip???
   / bx2660 bushhog squealer leaves strip??? #1
willbe
IL
Kubota BX2660
i have a bx2660 with a 4 ft bushhog squealer when i mow my 4 acres with it it will leave a 1 ft or so strip of grass on one side has anyone had trouble of this kind any help would be greatful
   / bx2660 bushhog squealer leaves strip??? #2
Clockwise or counterclockwise ?
Try going the other direction.
   / bx2660 bushhog squealer leaves strip??? #3
mow in a lower gear and you will not have the problem of rooster tails, also check to be sure one blade is not stuck in a narrower width or jammed on the rotor.
But if you and your buddies had a few and they crawled under there and changed one blade and put on backwards while you were not looking or beer was involved.................................................................................
Drive in a lower gear and if that does not solve it think about the last time the guys came over for beer ..........................................................
:eek::eek::rolleyes::D
   / bx2660 bushhog squealer leaves strip??? #5
willbe,
Is the grass just not cut ie, not touched by the blade or not cut down completely ie, knocked over?
Will,
Very useful information.
i have tried everything with no success going the opposite direction slower faster higher lower with no luck no matter what i do it will not mow it all down and it only does it on the right hand side the left side cuts perfect.
   / bx2660 bushhog squealer leaves strip??? #7
Raise the mower and inspect the blades that will be where your problem is
the grass is half cut and not cut at all after a day or so it will stand straight back up like it wasnt even cut
and the mower is only been used once so it is still very new but i will check the blades
   / bx2660 bushhog squealer leaves strip??? #10
RCs are pretty basic machines, gotta be something simple ?
If has a slip clutch, is it slipping ?
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2012 CASE IH 1230 LOT IDENTIFIER 173 (A53084)
2012 CASE IH 1230...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
HOMEMADE 4' X 4' DEER STAND (A51248)
HOMEMADE 4' X 4'...
