bx2660 bushhog squealer leaves strip???
   / bx2660 bushhog squealer leaves strip??? #1
willbe
IL
Kubota BX2660
i have a bx2660 with a 4 ft bushhog squealer when i mow my 4 acres with it it will leave a 1 ft or so strip of grass on one side has anyone had trouble of this kind any help would be greatful
   / bx2660 bushhog squealer leaves strip??? #2
Clockwise or counterclockwise ?
Try going the other direction.
   / bx2660 bushhog squealer leaves strip??? #3
mow in a lower gear and you will not have the problem of rooster tails, also check to be sure one blade is not stuck in a narrower width or jammed on the rotor.
But if you and your buddies had a few and they crawled under there and changed one blade and put on backwards while you were not looking or beer was involved.................................................................................
Drive in a lower gear and if that does not solve it think about the last time the guys came over for beer ..........................................................
:eek::eek::rolleyes::D
   / bx2660 bushhog squealer leaves strip??? #5
willbe,
Is the grass just not cut ie, not touched by the blade or not cut down completely ie, knocked over?
Will,
Very useful information.
i have tried everything with no success going the opposite direction slower faster higher lower with no luck no matter what i do it will not mow it all down and it only does it on the right hand side the left side cuts perfect.
   / bx2660 bushhog squealer leaves strip??? #7
Raise the mower and inspect the blades that will be where your problem is
the grass is half cut and not cut at all after a day or so it will stand straight back up like it wasnt even cut
and the mower is only been used once so it is still very new but i will check the blades
   / bx2660 bushhog squealer leaves strip??? #10
RCs are pretty basic machines, gotta be something simple ?
If has a slip clutch, is it slipping ?
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
RoGator RG1100C (A53472)
RoGator RG1100C...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2017 TAKEUCHI TB290 EXCAVATOR (A51246)
2017 TAKEUCHI...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
