BX2660 - 2nd cracked hardline
   / BX2660 - 2nd cracked hardline #1
mjribeiro
Hunterdon County NJ
Kubota BX2660
Guys - my 2010 BX2660 sprung a leak last year about 2 months from new. It was the hardline just above the rear PTO shroud. Dealer replaced no problem. That was July 2011. The same hardline has just developed a leak at the same fitting. Not a drip, a full power washer type stream.
Tractor is still under warranty, but there must be a design flaw here no? This tractor has maybe 50-60 hrs, mostly cutting the lawn. The leaks have sprung when using the bucket on heavy stuff - stone and dirt.
   / BX2660 - 2nd cracked hardline #2
We have 500 pretty hard hours on our 2660 with no problems.
   / BX2660 - 2nd cracked hardline #3
280 hours on my 2009 BX2660 with no problems. Good luck with yours. Maybe the tubing/fitting is just a defective one. Done a lot of heavy rock, gravel and log lifting with mine as well as routine mowing. Maybe somebody knowledgeable about hydraulics could comment on this.
   / BX2660 - 2nd cracked hardline #4
Hi.
If you try searching the forum you'll find my posts on the same issue. I had mine replaced two or three times. On the last time, the dealer put on a hydraulic hose, not the steel line. No problems since.
Very frustrating, but fixed now.
I'm not sure if it's a manufacturing problem with the line or fittings...
Chris
   / BX2660 - 2nd cracked hardline #5
my b7800 had a leak right close to where yours did. maybe even similar line. mine was from ramming too hard when pulling a large pine tree up hill.:confused2: it was my fault. dealer fixed for me under warrenty. no leaks back yet. that was at 75 hours. tractor now has 920 hours. good luck with your issue. hope it gets fixed perminently next time and you are back up and running soon.
   / BX2660 - 2nd cracked hardline #7
I would suspect the failure(s) are being caused by a slight misalignment between the hard line and the fittings. That is why some will run for hundreds of hours and others only a few hours. Over time the vibration and pressure cycles cause this joint to fail. Like others have said a properly sized hose will eliminate this problem.
Roy
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A51572)
1995 Chevrolet...
2023 JACTO ARBUS-1000 LOT NUMBER 69 (A53084)
2023 JACTO...
9ft x 7ft Shipping Container with Side Door (A51573)
9ft x 7ft Shipping...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
1994 Prevost Liberty Coach 40FT Class A Motorhome (A51694)
1994 Prevost...
RING 2 STARTS HERE @ 9:30 AM (A51247)
RING 2 STARTS HERE...
