BX25D won't go
/ BX25D won't go #1
Davenj4f
Kubota BX-25D
2019 BX25D. Suddenly, yesterday, it stopped going. Would not go forward or backwards. The foot pedals move as they should. The front and rear buckets work normally. Checked fluid, it was a little low, so topped it off. Still no go. Looked underneath to check linkages, and from what I can see, all ok. The skid plate hinders seeing better. I can't really afford to take to the dealer. But if I knew what the problem was, most likely I could fix it, but don't know what to check. Any help as what to check would be most appreciated.
Dave Hollywood SC
/ BX25D won't go
I would suspect the item 160 (rod) became disconnected at either end.
Kubota BX25 Parts Diagrams
or the pin where it controls the swash plate at the HST unit.
Thanks for the reply. Nope, all linkages appear ok. Rod 160 goes back to another swivel (?) which moves freely. The forward and back pedals move like they always have; smoothly with the springs, almost like shock absorber is attached.
It's almost time for fluid change. I don't suppose a clogged filter would be a culprit ?
/ BX25D won't go #4
Sound like the Swash plate inside the HST is not moving. The linkage ends with pin 230 in item 220 Trunion arm on this page. If the pin is sheared or missing he shaft into the HST will not move, no motion of the tractor if that shaft is not turning.
BTW there is a "shock" in the linkage to smooth out inputs.
If the shaft inside the trunion arm is moving you are either in neutral (or between ranges) , the HST is hung in neutral (linkage for shifting) or it something internal.
Same problem in all ranges?
/ BX25D won't go #5
Make sure the range selector is actually in gear. I bought a B7200hst a few years ago that would randomly lose all motion, everyone thought it was an HST problem but ended up being a broken shift fork for the range selector letting the gear slide back and forth in and out of neutral.
/ BX25D won't go
Well, put me on the dumb guy list. The tractor was in neutral. I was moving some large limbs, and some brushed by me on the side of the tractor. Apparently one of them pushed the high/low lever, and because I never put it in neutral, so it didn't occur to me to check that. TMGT's referral about being in neutral, the tires spinning (they wouldn't if in gear), the foot pedals feeling normal, the buckets operating normally, all that made me look at the lever. Oh well, and away we go...
Thanks to all who replied.
/ BX25D won't go #7
Glad it was an easy fix!
/ BX25D won't go #8
Now I am going to have to check my BX2200. I don't think there is a neutral position, only rabbit or turtle.
But I have learned not to trust my memory as much as I used to!
/ BX25D won't go #9
It should have a neutral, I know my dad's BX1500 does.
/ BX25D won't go #10
There is a neutral, at one point the safety switches made you be there in order to start. 2nd switch I bypassed :cool:
/ BX25D won't go #11
Sorry, I did check and there is a neutral position on my BX 2200 that I did not remember.
I meant to reply earlier, but could not find this thread for some reason...I must have been thinking of the PTO selector, which is different than my B2910, and just has off-on positions, with no foot clutch...never liked that.
/ BX25D won't go #12
Dave Hollywood SC
I have a TYM TL25 and mine was not going anywhere either with all the pedals working properly and it end up being the Las ik and Phil shaft assembly Universal ride that runs from the front to the back it's only about 12 inches long but it's got two universal joints on both ends and one of the universal head broke causing it not to choose go anywhere. It is actually located up under the skid plate so unless you crawl up under there with a flashlight and look you probably not going to be able to see it. I am actually looking for that part now if anyone knows where I might be able to buy that from
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
(INOP) JOHN DEERE 6120M TRACTOR (A64280)
(INOP) JOHN DEERE...
72in. Fork Extension (A61572)
72in. Fork...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61573)
2005 Stertil Koni...
2021 POLARIS PRO XD 4000D UTV (A64280)
2021 POLARIS PRO...
2011 Ford F-350 Utility Truck (A61573)
2011 Ford F-350...
