Bx25D want start its not the battery.
   / Bx25D want start its not the battery. #1
Kkcgz6
Killeen, Texas
BX25D
hello,
I need help on finding and checking the glow plug control on my tractor.
Any help would be appreciated!
   / Bx25D want start its not the battery. #2
First did you run it out of fuel ? is there water in the fuel ? did you just change the filters ? I have a bx 24 and it starts with out hitting the glow plugs .
   / Bx25D want start its not the battery. #3
I doubt that the air temperature in Texas is anywhere near needing glow plugs at this time of year. If it turns over but refuses to start I would suspect as stated above that the 1st thing to look at is fuel delivery.
   / Bx25D want start its not the battery. #4
How about a faulty fuel shut off solenoid?
On my RTV 900, which I'm pretty sure uses the same engine, it seems the solenoid is normally open. When I shut the machine off you can hear the fuel solenoid clicking over (to open) about five seconds after shut down. If your solenoid failed to open after you shut it off last time you have no fuel.
Turn the key on and crank it and then turn it back off, if you don't hear a click shortly thereafter you might have a faulty solenoid.
2013 MACK CXU613 SLEEPER (A50046)
2013 MACK CXU613...
2013 Ford F-150 (A50397)
2013 Ford F-150...
Terex Loader Arm (A49346)
Terex Loader Arm...
CAT 416C BACKHOE(INOPERABLE) (A48992)
CAT 416C...
SCAN FOR HAULING AND FINANCING INFORMATION (A50459)
SCAN FOR HAULING...
2014 Dynapac CC4200 (A50397)
2014 Dynapac...
