BX25 with Leaking Battery
   / BX25 with Leaking Battery #11
Some batteries may be rated for rougher service than others.:)
I got the 3 year free replacement battery balance pro rated for around $65.00.
If it dies it can go back they said it takes an hour for them to test it and if it fails you get a new battery.
tom
   / BX25 with Leaking Battery #12
Egon I think you are right, anyway it use to be that way. But I have not seen any 'rough service' application in quite a few years.
I think battery manufactures support the plates anticipating very rough service in all applications now...
Or perhaps they have noticed the deteriorating condition of out roads and highways, and just started making automotive batteries capable of lasting with that type of beating... KennyV
   / BX25 with Leaking Battery #13
A couple of years ago, my brand new B2630 had a leaky battery. At 50 hours, the radiator and all the hydraulic cooling lines had all the paint eaten away. Battery tray severely corroded. I disassembled the whole mess, cleaned, repainted and replaced the battery with an Optima sealed battery. Two years later, no problems. Couldn't be happier. I don't know if these little tractors overcharge the batteries or if it's just the bouncing around, but the problem is fairly common. John Deere sells a battery box to contain their leaks - terrible 'fix' in my opinion.
You can find other sealed batteries besides the Optimas as well. My Optima was purchased on Amazon.com for $141.00. You can ship these batteries as they are sealed.
Can you tell me what the model # of Optima battery you purchased?
Thanks in advance
DGS
   / BX25 with Leaking Battery #14
I bought the Optima Yellow Top D51R. It is an Optima 8073-167. It's been flawless for 100 hrs. now.
Battery Specifications
Part# 8073-167
Model# D51R
Connections: Top SAE / BCI automotive posts only.
Length: 9.313"
Width: 5.063"
Height: 8.938" (height at the top of the terminals)
Weight: 26.0 lbs.
CCA: 450 Amps
MCA: 575 Amps
RC: 66 Minutes
It's $144.77 right now on Amazon.com with free shipping.
Check Optima battery site for specific sizes and configurations to meet your needs. For instance, you can get the same battery with the posts oriented differently.
Hope this helps.
Well, I drug my feet and wasn't able to go comparison shopping. I needed to mow yesterday and ended up just heading over to my local Autozone and picking up a Duralast for $85 w/ core exchange.
Model 26R-DL
7 YR Notes: *** 575 cold cranking Amps (710 cranking Amps) *** 90 reserve minutes. -> 2 year free replacement
For what it's worth, to make it easier to get a replacement you can use a 2005 Dodge Neon as your 'replacement vehicle' since no auto places keep tractor data around. It's the exact size you'll need for the BX25 and the terminals are in the correct orientation.
I'm still ticked that the original battery developed a crack / leak in the case after only 16 months and 83 hours. Actually, there is no telling how long the leak had been going on. If I'd noticed before February I could have got a replacement under warranty! I wonder why it is that the original $200 battery only had a 12 month warranty while my $85 replacement carrys a 7 year with a 2 year no questions asked warranty... hmmm.
UNUSED FUTURE SKID STEER HYD MIXING BUCKET (A51244)
UNUSED FUTURE SKID...
2013 FORD Taurus (A50324)
2013 FORD Taurus...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52128)
2021 John Deere...
Woods 3 pt RM 550 Finishing Mower (A50515)
Woods 3 pt RM 550...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
