That needle type of tip is meant for really crowded u-joints, where there isn't enough space for a normal zerk fitting; the fittings on these will have a concave cup-type of face to insert the pin/needle into, which only protrudes about 1/8" from the face of the u-joint's center cross. IIRC, my '72 Blazer used those on the front driveshaft CV joint, which was made up of two u-joints short-coupled in a steel housing.
I've also used the needle tip on normal zerk fittings that are just plain hard to get at- it takes some good aim, but you can just push the needle into the teensy ball check valve on the tip of the zerk fitting and pump.
