BX25 King kutter install questions.
/ BX25 King kutter install questions. #1
Mcaveman
Maryland
Own Z121S, BX25 purchased w 35 hrs
Need help with hows to measure shaft.
Also I have the shaft split right now the tractor half is hooked up, the tiller half only slides over shaft about 1 inch , this cant be right am i missing something?
Also how do i measure and cut down the shafts?
Thanks
BX25 and king kutter xb
Does the shaft that goes on the tiller how does that stay on that bolt?
/ BX25 King kutter install questions. #4
Pictures are worth a thousand words , let us see exactly what you have . Do you have some type of clutch system ? If not you will need a sheer bolt to protect your tractor pto . The two shafts will need more than 1 inch overlap for sure , sounds like you need a longer one for your tractor. Did you watch the you tube video Zick pointed you too , that should answer most questions ?
After watching the video, I called them and they were very helpful , got it on and running but ran out of daylight.
/ BX25 King kutter install questions. #6
Glad you were able to get up and running, be careful and have fun .
Does anyone know if pats easy change will work with this? That's on my wish list if it will work.
/ BX25 King kutter install questions. #8
I dont know if they will work with that particular implement, a pic of the 2 pins would help. But i have them and they work great. They only thing they dont work on is my ballast box. Gonna have to get a different model.
/ BX25 King kutter install questions. #9
I had quick hitches and couldn't use them with my tiller because it had to much slack on one which kept breaking a piece and the other quick hitch extended the tiller back to far for the shaft and I believe that was my Pats..
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
2009 Ford F-550 Versalift Signalier ATR-41 41ft. Bucket Truck (A61573)
2009 Ford F-550...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
2015 Freightliner M2 106 Petersen TL3 Forestry Grapple Truck (A61573)
2015 Freightliner...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
