BX25 King kutter install questions.
   / BX25 King kutter install questions. #1
Mcaveman
Maryland
Own Z121S, BX25 purchased w 35 hrs
Need help with hows to measure shaft.
Also I have the shaft split right now the tractor half is hooked up, the tiller half only slides over shaft about 1 inch , this cant be right am i missing something?
Also how do i measure and cut down the shafts?
BX25 and king kutter xb
Does the shaft that goes on the tiller how does that stay on that bolt?
   / BX25 King kutter install questions. #4
Pictures are worth a thousand words , let us see exactly what you have . Do you have some type of clutch system ? If not you will need a sheer bolt to protect your tractor pto . The two shafts will need more than 1 inch overlap for sure , sounds like you need a longer one for your tractor. Did you watch the you tube video Zick pointed you too , that should answer most questions ?
After watching the video, I called them and they were very helpful , got it on and running but ran out of daylight.
   / BX25 King kutter install questions. #6
Glad you were able to get up and running, be careful and have fun .
Does anyone know if pats easy change will work with this? That's on my wish list if it will work.
   / BX25 King kutter install questions. #8
I dont know if they will work with that particular implement, a pic of the 2 pins would help. But i have them and they work great. They only thing they dont work on is my ballast box. Gonna have to get a different model.
   / BX25 King kutter install questions. #9
I had quick hitches and couldn't use them with my tiller because it had to much slack on one which kept breaking a piece and the other quick hitch extended the tiller back to far for the shaft and I believe that was my Pats..
Ryobi Compound Miter Saw (A48837)
Ryobi Compound...
82" Pallet Fork Extensions, New (A47371)
82" Pallet Fork...
2019 KENWORTH T680 DAY CAB (A50046)
2019 KENWORTH T680...
BANDSAW W/ ROLLER TABLE (A48992)
BANDSAW W/ ROLLER...
Headache Rack (A47371)
2015 Toyota Prius C Hybrid Hatchback (A46684)
2015 Toyota Prius...
