J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,952
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Your leak down could just as easily be the control valve, and not the cyl.
Here's the link I built. I bought the cylinder (2.5"x8"), pilot check valve & hoses from Surplus Center. The cylinder originally had clevis ends, I bought 2 weld-on swivel eye ends from Tractor Supply and cut them off by hand with a hacksaw. I was able to get the exact length I needed this way to fit my tractor's needs. Borrowed a friend's welder and installed the swivel ends. This rig has worked well for about 5 years for me so far and it has taken quite a bit of heavy work. I've got less than $180 in the whole thing, fittings and all.
For most of my uses, the ability to go shorter is more important than going longer, especially for the boxblade and bushog and transporting the finish mower. I used my boxblade as the guide when figuring the length I needed and it worked well for everything else. For my 2 bottom plow I have to use a very long top link and it's the only implement I can't use my cylinder with and have a dedicated mechanical link set for it.
I added an HTL to my BX last Spring. I read various post here about the shorter lenght of the top link being more important than the fully extended length and decided to go with a SC swivel eye 13"-19" cylinder. This was the closest I could find to the stock 14"-22" top link. Unlike most, however, I wish I had gone longer, but this could be implement dependent....
