BX25 floor pan
/ BX25 floor pan #1
cthusker
Norfolk, Ct
BX25
Does anyone have a part number for a BX25 floor pan? Mine is rusted out pretty bad and I'd like to simply replace as opposed to trying to fix it... thanks
/ BX25 floor pan #2
You can try this number, may need to be more specific as to which BX25 you have.
Called a step, there are other part numbers depending on model such as K2581-55154.
Part Number K2883-55150
Vendor Kubota
Messick's Price $88.15
Stock Quantity 1
Weight 10.00 lbs
Days to Order In stock
Replaces K2692-55050, K2581-55154
/ BX25 floor pan
Thank you very much and it's most appreciated... :thumbsup:
/ BX25 floor pan #4
For about $15 you can do what I did with a scuff pad on your drill and a can of bed liner.
Before and after.
/ BX25 floor pan
Thanks... I'm going to give that a try at least for now. Mine's in pretty rough shape with rust starting to go completely through with open holes. However perhaps I can salvage it as opposed to spending about a 100 bucks!! Thanks again.. yours looks excellent....
/ BX25 floor pan #6
Back when I bought my L3700SU, if had a plain painted floor board, no rubber mat. I removed it in the first few days as well as the step and center cover..and had them sprayed top and under with Linex....still looks like day 1.
/ BX25 floor pan
I wish I has thought of that because I had my new F150 Line-X'd immediately upon buying it......... that would certainly solve the rust problem!!
/ BX25 floor pan #8
Thanks! Maybe you can pop rivet some sheet metal over the part that is rusting through?
Then give it the scuff and liner treatment. Probably last 10 years or more!
/ BX25 floor pan #9
I like the bed liner idea. My mat is worn out. I have never liked it, hard to clean under it w/o removing it and several mat fasteners are now missing. I need to pull the pan to get to another irritating situation. Good time to remedy it. Thanks for the catalyst.
Ron
/ BX25 floor pan #10
Ron
You are welcome! For an hours work it really is a no brainer. Each time I lifted the mat to hose it off I would think ( I have to do something about this bad situation.)
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2022 Tesla Model 3 Long Range AWD Sedan (A61574)
2022 Tesla Model 3...
FLEX HEADER REEL FOR 20' HEAD (A63291)
FLEX HEADER REEL...
2015 LeeBoy 8510C Asphalt Paver (A61572)
2015 LeeBoy 8510C...
2022 EZ-GO ELITE...
